Add a Gigabit network port to your computer, using a USB Type-C connection. The RJ45 port supports multiple speeds (10/100/1000 Mbps) and is fully compatible with Cat5 (and higher) cabling. Share or receive files over a network, access network storage/backup, and stream online content while reducing wait times and slowdowns. This adapter supports both current and legacy Ethernet networks down to 10Mbps, making it ideal for providing a reliable network connection almost anywhere whether at home, work or while traveling. The USB-C host connector with attached USB-C to USB-A dongle offers compatibility with laptops, desktop computers, and 2-in-1's. The Realtek chipset is broadly supported on new and older laptops enabling PXE capabilities to aid IT departments with provisioning and maintaining systems along with Wake-on-LAN (WoL) support. The adapter provides a wired connection that is faster and more secure than wireless, making it ideal for IT professionals. Simply connect the network adapter to your computer's USB Type-C port. This USB-C to RJ45 adapter features VLAN tagging, 9K Jumbo Frames, Wake-on-LAN, Status LEDs and full-duplex Ethernet making it the perfect companion for on-the-go users who require a wired network connection. The USB Gigabit network adapter is light and compact. It features a built-in 6in (15cm) cable provides extended reach and improved flexibility, while reducing cable/connector strain. Additionally, USB bus power simplifies the setup and makes it a convenient accessory while on the move.
1 Gigabit Network Connection
This adapter supports both current and legacy Ethernet networks down to 10Mbps, making it ideal for providing a reliable network connection almost anywhere whether at home, work or while traveling. The USB-C host connector with attached USB-C to USB-A dongle offers compatibility with laptops, desktop computers, and 2-in-1's. The Realtek chipset is broadly supported on new and older laptops enabling PXE capabilities to aid IT departments with provisioning and maintaining systems along with Wake-on-LAN (WoL) support. The adapter provides a wired connection that is faster and more secure than wireless, making it ideal for IT professionals. -
Plug and Play Device Configuration
Simply connect the network adapter to your computer's USB Type-C port. This USB-C to RJ45 adapter features VLAN tagging, 9K Jumbo Frames, Wake-on-LAN, Status LEDs and full-duplex Ethernet making it the perfect companion for on-the-go users who require a wired network connection. -
Compact and Versatile Design
- StarTech.com USB-C to Ethernet Adapter w/USB-A Adapter, Realtek RTL8153B - network adapter - USB-C 3.2 Gen 1 - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB-C 3.2 Gen 1
- Ports
- Gigabit Ethernet
- 2.15 cm x 1.5 cm
- 26 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- Capacity
- Jumbo frame size: 9000
- Processor
- Realtek Semiconductor RTL8153B
- IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE 802.3x
- Space grey
- System Requirements
- Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Sequoia 15.0, Apple macOS Sonoma 14.0, Apple macOS Ventura 13.0, Apple MacOS X 10.11 - 10.15, Linux Kernel 2.4.20 or later (LTS versions only), Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2008 R2 / 2012 R2 / 2016 / 2022, Windows 11 (on ARM), Google Chrome OS, Apple iOS
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB-C 3.2 Gen 1
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- Capacity
- Status Indicators
- Link/activity, speed
- Auto-uplink (auto MDI/MDI-X), VLAN Tagging, WOL, PXE support, full duplex mode, promiscuous mode, USB powered, auto-negotiation, EEE, Thunderbolt compatible
Processor / Memory
- Processor
- 1 x 1000Base-T - RJ-45 - female
- Cables Included
- 1 x USB-C cable (integrated) - 15.2 cm , 1 x USB-C to USB-A adapter (external)
- MTBF
- 1,969,065 hours
- Space grey
- OS Required
- 2.15 cm
- 1.5 cm
- 26 g
- Shipping Width
- 12.8 cm
- Shipping Depth
- 2.2 cm
- Shipping Height
- 1.5 cm
- Shipping Weight
- 35 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 85% RH (non-condensing)
