StarTech.com USB-C to Ethernet Adapter
Quicklinx: J4KCWS00 Mfr#: C21GA-USB-ETHERNET
20 In Stock
£21.38 ex VAT
£25.65 inc VAT
Add a Gigabit network port to your computer, using a USB Type-C connection. The RJ45 port supports multiple speeds (10/100/1000 Mbps) and is fully compatible with Cat5 (and higher) cabling. Share or receive files over a network, access network storage/backup, and stream online content while reducing wait times and slowdowns. This adapter supports both current and legacy Ethernet networks down to 10Mbps, making it ideal for providing a reliable network connection almost anywhere whether at home, work or while traveling. The USB-C host connector with attached USB-C to USB-A dongle offers compatibility with laptops, desktop computers, and 2-in-1's. The Realtek chipset is broadly supported on new and older laptops enabling PXE capabilities to aid IT departments with provisioning and maintaining systems along with Wake-on-LAN (WoL) support. The adapter provides a wired connection that is faster and more secure than wireless, making it ideal for IT professionals. Simply connect the network adapter to your computer's USB Type-C port. This USB-C to RJ45 adapter features VLAN tagging, 9K Jumbo Frames, Wake-on-LAN, Status LEDs and full-duplex Ethernet making it the perfect companion for on-the-go users who require a wired network connection. The USB Gigabit network adapter is light and compact. It features a built-in 6in (15cm) cable provides extended reach and improved flexibility, while reducing cable/connector strain. Additionally, USB bus power simplifies the setup and makes it a convenient accessory while on the move.
  • 1 Gigabit Network Connection
  • Plug and Play Device Configuration
  • Compact and Versatile Design
StarTech.com USB-C to Ethernet Adapter w/USB-A Adapter, Realtek RTL8153B - network adapter - USB-C 3.2 Gen 1 - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
USB-C 3.2 Gen 1
Ports
Gigabit Ethernet
2.15 cm x 1.5 cm
26 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
Jumbo frame size: 9000
Realtek Semiconductor RTL8153B
IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE 802.3x
Space grey
Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Sequoia 15.0, Apple macOS Sonoma 14.0, Apple macOS Ventura 13.0, Apple MacOS X 10.11 - 10.15, Linux Kernel 2.4.20 or later (LTS versions only), Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2008 R2 / 2012 R2 / 2016 / 2022, Windows 11 (on ARM), Google Chrome OS, Apple iOS
Network adapter
External
USB-C 3.2 Gen 1
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Link/activity, speed
Auto-uplink (auto MDI/MDI-X), VLAN Tagging, WOL, PXE support, full duplex mode, promiscuous mode, USB powered, auto-negotiation, EEE, Thunderbolt compatible
Processor / Memory
1 x 1000Base-T - RJ-45 - female
1 x USB-C cable (integrated) - 15.2 cm , 1 x USB-C to USB-A adapter (external)
MTBF
1,969,065 hours
Space grey
2.15 cm
1.5 cm
26 g
Shipping Width
12.8 cm
Shipping Depth
2.2 cm
Shipping Height
1.5 cm
Shipping Weight
35 g
45 °C
10 - 85% RH (non-condensing)
