N/A. This USB-C to DVI adapter lets you connect a USB-C laptop, such as an Ultrabook or MacBook Pro, to a DVI display. The video adapter features USB Power Delivery, which enables you to power and charge your laptop while you're outputting video to a DVI display. To match the aesthetics of your device, this adapter is colored white.
USB Type-C is a universal connectivity standard that combines all of your essential functions into one dynamic port. This adapter works with USB-C devices that pass a DisplayPort video signal, such as the latest MacBook or Windows laptops. It's also compatible with Thunderbolt 3 ports.
Unlike some video adapters that use up one of your laptop's USB-C ports to output video, this video adapter offers an additional USB-C charge port that supports USB Power Delivery up to 60 watts. This means you can charge your laptop and output video using the same laptop port, by simply connecting the laptop's power adapter to the additional USB-C port on the adapter. It's the perfect solution for laptops that have only a limited number of USB-C ports.
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design. It's the perfect accessory to carry with your device, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so no matter how you plug it in, the adapter will always connect. This saves you the hassle and embarrassment of struggling with your device when you're trying to deliver a presentation or sharing information.
Charge your device at the same time
Unlike some video adapters that use up one of your laptop's USB-C ports to output video, this video adapter offers an additional USB-C charge port that supports USB Power Delivery up to 60 watts. This means you can charge your laptop and output video using the same laptop port, by simply connecting the laptop's power adapter to the additional USB-C port on the adapter. It's the perfect solution for laptops that have only a limited number of USB-C ports. -
Take it with you
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design. It's the perfect accessory to carry with your device, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this adapter perfect for BYOD applications at the office. -
Connect quickly
- StarTech.com USB C to DVI Adapter with Power Delivery, 1080p USB Type-C to DVI-D Single Link Video Display Converter with Charging, 60W PD Pass-Through, Thunderbolt 3 Compatible, White - USB-C Display Adapter (CDP2DVIUCPW) - external video adapter - Parade PS171 - white
- External video adapter
- Bus Type
- USB-C
- Graphics Engine
- Parade PS171
- Max Resolution
- 1920 x 1200
- Interfaces Details
- DVI-I
- 3.3 cm x 5 cm x 1.3 cm
- Enclosure Colour
- White
- 3-year warranty
- Bus Type
- USB-C
- Graphics Engine
- Parade PS171
- Max Resolution
- 1920 x 1200 at 60 Hz
- DVI-I
- USB powered, Thunderbolt 3 compatible
Video Input
- USB powered
- FCC, RoHS, WEEE
- 3.3 cm
- 5 cm
- 1.3 cm
- 24 g
- Enclosure Colour
- White
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 0 - 90% (non-condensing)
StarTech.com USB-C to VGA Adapter | In Stock | £22.16 |
StarTech.com USB-C to HDMI Adapter | In Stock | £15.94 |
StarTech.com USB-C to HDMI Adapter | In Stock | £15.52 |
StarTech.com USB-C to 4K HDMI Adapter w/ PD | In Stock | £20.98 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £22.59 |
StarTech.com USB-C to DVI with USB PD | In Stock | £10.14 |
