Connect your MacBook, Chromebook or laptop with USB-C to a DVI monitor or projector. This USB-C to DVI adapter lets you output DVI video from a USB Type-C device such as a MacBook, Chromebook or Dell XPS laptop. The adapter works with USB-C devices that pass a DisplayPort video signal and it's also compatible with Thunderbolt 3 ports.
This USB Type-C video adapter is highly portable, with a small footprint and a lightweight design. It's the perfect accessory for your MacBook or Chromebook, fitting easily into your laptop bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
The adapter supports dual-link video resolutions up to 2560x1600. You'll be surprised at the picture quality the adapter provides, even when connected to a DVI monitor, projector or television. The adapter harnesses the video capabilities that are built into your USB Type-C connection, to deliver every detail in stunning resolution.
This adapter lets you enjoy the versatility of your portable device's USB-C port. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work.
The CDP2DVI features a black housing that looks great with your ChromeBook Pixel.
Your USB-C equipped device must support video to work with this adapter. Some legacy DVI monitors may be limited to a resolution of 1920x1200 when used with this adapter.
  • Clutter-free installation
    At 2 m (6 ft.) in length, the adapter cable delivers a direct connection between your USB-C device and your DVI monitor. This means you don't have to use additional adapters or cabling, which helps ensure a tidy and professional installation.
  • Hassle-free connection with USB Type-C
    The USB-C to DVI adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
  • Crystal-clear picture quality
    The adapter harnesses the video capabilities that are built into your USB Type-C connector to deliver video resolutions up to 2560x1600, providing full dual-link support for your high-resolution DVI monitors - great for multitasking on high-resolution DVI displays. The adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other HD work environments.
StarTech.com USB C to DVI Adapter - Black - 1920x1200 - USB Type C Video Converter for Your DVI D Display / Monitor / Projector (CDP2DVI) - video / USB adapter - 24 pin USB-C to DVI-I
Video / USB adapter
1920 x 1200 (WUXGA) support, DisplayPort Alternate Mode support
Connector
24 pin USB-C - male (input)
Connector (Second End)
24+5 pin combined DVI - female (output)
Thunderbolt 3
3-year warranty
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, TB33A1C, TB4CDOCK
Video / USB adapter
3.7 cm
16.2 cm
1.45 cm
28 g
Connector
Thunderbolt 3, FCC, RoHS
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Weight
36 g
3-year warranty
C1B1 StarTech.com USB-C to VGA Adapter In Stock £23.98
C1B1 StarTech.com USB-C to VGA Adapter - White In Stock £21.61
C1B1 StarTech.com USB-C to HDMI Adapter In Stock £22.02
C1B1 StarTech.com USB-C to HDMI Adapter In Stock £22.69
C1B1 StarTech.com 2m USB-C to DVI Cable In Stock £24.14
C1B1 StarTech.com 2m USB-C to HDMI Cable In Stock £31.44
C1B1 StarTech.com 1m USB-C to HDMI Cable In Stock £27.99
C1B1 StarTech.com USB-C to HDMI Presentation In Stock £40.26
C1B1 StarTech.com 2m USB C to HDMI Cable - Black In Stock £27.71
C1B1 StarTech.com 1m USB C to HDMI Cable - Black In Stock £27.65
C1B1 StarTech.com 3m USB C to HDMI Cable - Black In Stock £28.99
C1B1 StarTech.com 1m USB C to HDMI Cable - White In Stock £24.31
C1B1 StarTech.com USB-C to DVI Adapter - Dual-Link Connectivity - Active Conve In Stock £40.69
C1B1 StarTech.com Portable USB C to Mini DisplayPort Adapter w/ Keychain In Stock £11.28
C1B1 StarTech.com USB C to mDP Adapter 12" Cable In Stock £25.88
