StarTech.com USB-C to DVI Adapter - Dual-Link Connectivity - Active Conve
Quicklinx: FC01WS00 Mfr#: CDP2DVIDP
Length: 15.2cm
£36.73 ex VAT
£44.07 inc VAT
This USB-C to DVI adapter lets you connect your USB Type-C device to any DVI-D display, including televisions, Apple Cinema HD Display and other DVI dual-link monitors.
With an active conversion, this USB Type-C to DVI adapter ensures compatibility with DVI dual-link monitors and displays, which eliminates having to upgrade your DVI display to a newer model for the sake of compatibility.
With its compact, lightweight design, this active USB-C to DVI-D adapter offers a convenient travel accessory to carry with your USB-C-equipped computer, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this display adapter perfect for BYOD (Bring Your Own Device) applications at the office, or on the road.
As well, this DVI converter is powered by the host device's USB-C port, eliminating the need for additional cords or chargers.
This DVI adapter can handle full dual-link resolutions up to 2560x1600 with the ability to mirror your display or extend your desktop. Alternatively, the USB 3.1 to DVI adapter can support single-link displays with resolutions up to 1920x1080.
With easy plug-and-play connectivity, this DVI video adapter offers a hassle-free setup.
  • Ideal for travel
    With its compact, lightweight design, this active USB-C to DVI-D adapter offers a convenient travel accessory to carry with your USB-C-equipped computer, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this display adapter perfect for BYOD applications at the office, or on the road.
  • Uncompromised picture quality
    This DVI adapter can handle full dual-link resolutions with the ability to mirror your display or extend your desktop.
StarTech USB 3.1 Type-C to Dual Link DVI-I Adapter - Digital Only - 2560 x 1600 - Active USB-C to DVI Video Adapter Converter (CDP2DVIDP) - video adapter - USB-C to DVI-I - 15.2 cm
Video adapter - dual link
Active cable, metal body, DisplayPort Alternate Mode support, maximum resolution 2560x1600 at 60 Hz
Cable Length
15.2 cm
Connector
24 pin USB-C - male (input)
Connector (Second End)
24+5 pin combined DVI - female (output)
USB 3.1
Space grey
3-year warranty
P/N: TB4CDOCK
Video adapter
TMDS Links
Dual link
Cable Length
15.2 cm
Space grey
4.5 cm
8.6 cm
1.3 cm
65 g
Connector
USB 3.1, Plug and Play, FCC, RoHS, REACH
Shipping Width
14.4 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
100 g
3-year warranty
P/N: TB4CDOCK
FC01 StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £41.39
FC01 StarTech.com USB-C to VGA Adapter In Stock £21.67
FC01 StarTech.com USB-C to HDMI Adapter In Stock £15.52
Length: 15.2cm
