This USB-C to DVI adapter lets you connect your USB Type-C device to any DVI-D display, including televisions, Apple Cinema HD Display and other DVI dual-link monitors.
With an active conversion, this USB Type-C to DVI adapter ensures compatibility with DVI dual-link monitors and displays, which eliminates having to upgrade your DVI display to a newer model for the sake of compatibility.
With its compact, lightweight design, this active USB-C to DVI-D adapter offers a convenient travel accessory to carry with your USB-C-equipped computer, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this display adapter perfect for BYOD (Bring Your Own Device) applications at the office, or on the road.
As well, this DVI converter is powered by the host device's USB-C port, eliminating the need for additional cords or chargers.
This DVI adapter can handle full dual-link resolutions up to 2560x1600 with the ability to mirror your display or extend your desktop. Alternatively, the USB 3.1 to DVI adapter can support single-link displays with resolutions up to 1920x1080.
With easy plug-and-play connectivity, this DVI video adapter offers a hassle-free setup.
Ideal for travel
With its compact, lightweight design, this active USB-C to DVI-D adapter offers a convenient travel accessory to carry with your USB-C-equipped computer, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this display adapter perfect for BYOD applications at the office, or on the road. -
Uncompromised picture quality
This DVI adapter can handle full dual-link resolutions with the ability to mirror your display or extend your desktop.
- StarTech USB 3.1 Type-C to Dual Link DVI-I Adapter - Digital Only - 2560 x 1600 - Active USB-C to DVI Video Adapter Converter (CDP2DVIDP) - video adapter - USB-C to DVI-I - 15.2 cm
- Video adapter - dual link
- Active cable, metal body, DisplayPort Alternate Mode support, maximum resolution 2560x1600 at 60 Hz
- Cable Length
- 15.2 cm
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- 24+5 pin combined DVI - female (output)
- USB 3.1
- Space grey
- 3-year warranty
- Designed For
- P/N: TB4CDOCK
- Video adapter
- TMDS Links
- Dual link
- Cable Length
- 15.2 cm
- Space grey
- 4.5 cm
- 8.6 cm
- 1.3 cm
- 65 g
- Connector
- USB 3.1, Plug and Play, FCC, RoHS, REACH
- Shipping Width
- 14.4 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 100 g
- 3-year warranty
- Designed For
- P/N: TB4CDOCK
StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 | In Stock | £41.39 |
StarTech.com USB-C to VGA Adapter | In Stock | £22.16 |
StarTech.com USB-C to HDMI Adapter | In Stock | £15.52 |
