StarTech.com USB-C to Dual-HDMI Adapter
Quicklinx: HDG1WS00 Mfr#: 109B-USBC-HDMI
£96.13 ex VAT
£115.35 inc VAT
Connect two 4K 60Hz HDMI displays to the USB Type-C or Type-A port of a laptop/desktop computer, using this USB-C to Dual-HDMI Adapter.
  • Power Delivery Pass-Through
    The USB video adapter features USB Power Delivery (PD) 3.0 pass-through (up to 100W), enabling powering and charging of a laptop when connected to a USB-C power adapter. The adapter runs on USB bus-power when no USB-C power adapter is connected. PD 3.0 features Fast Role Swap (FRS) that prevents USB data disruption when USB-C power is disconnected and the adapter switches to USB bus power.
  • DisplayLink Certified 4K 60Hz Resolution
    The USB multi-monitor adapter is DisplayLink Certified and supports high-performance dual-monitor 4K 60Hz video resolutions with an integrated DisplayLink DL-6950 Controller.
  • Comprehensive Compatibility
    The USB video adapter is compatible with Windows, macOS, Ubuntu, and Chrome OS. The integrated USB-C to USB-A adapter enables the flexibility of connecting to any host that is running a compatible operating system. The built-in 1ft (30cm) USB-C/A cable is ideal for on the go use. The length of the cable and the strain reliefs reduce connector/port strain. This product is backed for 3-years by StarTech.com, including free 24/5 multi-lingual technical assistance.
StarTech.com USB-C to Dual-HDMI Adapter, USB-C or A to 2x HDMI, 4K 60Hz, 100W PD Pass-Through, 1ft (30cm) Built-in Cable, External Video Graphics Adapter - USB to HDMI Multi-Monitor Converter for Laptop (109B-USBC-HDMI) - adapter - HDMI / USB - TAA Compliant - 30 cm
Cable
Adapter - HDMI / USB
TAA Compliant
Max Output Resolution
3840 x 2160 - 60 Hz
Length
30 cm
Grey
Connectors
USB Type A - male , 24 pin USB-C - male
Connectors (Second End)
2 x HDMI - female
USB 3.2 Gen 1
4K support, active adapter
3-year warranty
Cable Type
Adapter 4K support, active
Interface Supported
HDMI / USB
USB 3.2 Gen 1
Length
30 cm
Bus powered, Host USB-C Power Adapter, aluminum enclosure, 100W power delivery
Grey
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Microsoft Windows 7 / 8 / 10 / 11, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Google Chrome OS, Ubuntu 18.04, Ubuntu 20.04, Apple MacOS Sierra, Apple macOS X El Capitan
Connectors
9 pin USB Type A - male , 24 pin USB-C - male
2 x 19 pin HDMI Type A - female
FCC, WEEE, UKCA, DisplayLink certified, RoHS
TAA Compliant
11.3 cm
2.4 cm
1.5 cm
121 g
Shipping Width
11.4 cm
Shipping Depth
6 cm
Shipping Height
1.6 cm
Shipping Weight
180 g
Limited warranty - 3 years
HDG1 StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £16.49
HDG1 StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £20.48
HDG1 StarTech.com 10ft Ultra High Speed HDMI 2.1 In Stock £23.74
