StarTech.com USB-C to Dual GbE Adapter
Quicklinx: CFQFWS00 Mfr#: US1GC301AU2R
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Ethernet, Fast Ethernet
Form Factor: External
Compatibility: PC, Mac
Type: Network adapter
14 In Stock
£57.13 ex VAT
£68.55 inc VAT
Use the USB-C port on your laptop to add LAN access with two Gigabit Ethernet ports and a USB 3.0 (Type-A) port. Now, you can add wired network access through the USB-C or Thunderbolt 3 port on your laptop or desktop computer, and connect to your USB 3.0 (Type A) devices with ease. This Gigabit Ethernet network adapter gives you access to two reliable GbE ports, and without having to install drivers. It's a great companion for your MacBook, Chromebook Pixel, Dell XPS 12, Dell Latitude 12 7000 Series 2-in-1 or another device that has a USB Type-C port.
The network adapter leverages the 5Gbps speed of USB 3.0 (also known as USB 3.1 Gen 1) to deliver the full bandwidth of your Gigabit network connection, without bottlenecks. This saves you time by making it easier to access very large files over your network at Gigabit speed.
For added versatility, the network adapter supports a range of convenient features, such as Wake-On-LAN, VLAN Tagging, Crossover Detection and Auto-Correction (Auto MDIX), Checksum Offload (IPv4, IPv6, TCP, UDP), and Large Send Offload.
Some computers with USB Type-C only offer one USB-C port for external connectivity, which will not connect with your existing USB Type-A devices. This Gigabit adapter features an integrated USB 3.0 Type-A port, so while the adapter is connected to your computer to provide network access, you can also connect to USB peripherals that need a USB Type-A connector. The network adapter is also backward compatible with USB 2.0 systems.
Native driver support makes installation easy
Get up and running quickly. The network adapter provides native driver support to ensure a quick setup. Simply plug the adapter into the USB Type-C port on your laptop and connect to your network. The network adapter chipset offers native driver support in Chrome OS and Windows 8.1, and supports Mac OSX (10.10) with driver installation.
The USB Type-C connector is smaller and easier to use than previous USB connectors. It's a reversible plug, so you can connect to your devices with either side facing up. You can insert the cable the right way every time, without frustration or the risk of port damage.
  • Powerful Gigabit network connections
    The network adapter leverages the 5Gbps speed of USB 3.0 (also known as USB 3.1 Gen 1) to deliver the full bandwidth of your Gigabit network connection, without bottlenecks. This saves you time by making it easier to access very large files over your network at Gigabit speed. For added versatility, the network adapter supports a range of convenient features, such as Wake-On-LAN, VLAN Tagging, Crossover Detection and Auto-Correction (Auto MDIX), Checksum Offload (IPv4, IPv6, TCP, UDP), and Large Send Offload.
  • Add connectivity to your USB devices
  • Native driver support makes installation easy
  • Trouble-free connections through USB-Type-C
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Mac Address Pass-Through Utility : To improve network security. •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB-C to Dual Gigabit Ethernet Adapter with USB 3.0 (Type-A) Port - USB Type-C Gigabit Network Adapter (US1GC301AU2R) - network adapter - USB-C - Gigabit Ethernet x 2 + USB 3.0
Network adapter
External
Interface (Bus) Type
USB-C
Ports
6 cm x 7.5 cm x 1.6 cm
59 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3az
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
P/N: TB33A1C
Network adapter
External
USB-C
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Link/activity
Full duplex capability, auto-uplink (auto MDI/MDI-X), USB powered, Energy Efficient Ethernet, 4K resolution support, USB Pass-Through, VLAN Tagging (not supported in MacOS)
2 x 1000Base-T - RJ-45 - female , 1 x USB 3.0 - 9 pin USB Type A - female
1 x SuperSpeed USB-C cable (integrated)
FCC, RoHS
6 cm
7.5 cm
1.6 cm
59 g
5 °C
50 °C
20 - 80%
P/N: TB33A1C
CFQF StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter In Stock £23.78
CFQF StarTech.com USB-C to Gigabit Adapter In Stock £24.73
CFQF StarTech.com USB-C to Gigabit Adapter In Stock £24.60
CFQF StarTech.com USB-C to Gigabit Adapter In Stock £37.35
CFQF StarTech.com USB-C to Dual GbE Adapter In Stock £57.13
CFQF StarTech.com USB-C to Ethernet Adapter In Stock £15.23
Protocol: Ethernet
Protocol: Fast Ethernet
Compatibility: PC
Compatibility: Mac
