StarTech.com USB-C to DP with USB PD
Quicklinx: D384WS00 Mfr#: CDP2DPUCP
£16.26 ex VAT
£19.51 inc VAT
Use this USB Type-C to DisplayPort adapter to output DP video and charge your laptop using a single USB-C port. This USB-C to DisplayPort adapter lets you connect your laptop or MacBook with USB Type-C to a DisplayPort monitor. The video adapter features USB Power Delivery, which enables you to power your laptop while you're outputting video to a DisplayPort display.
USB Type-C is a universal connectivity standard that combines all of your essential functions into one dynamic port. This adapter works with USB-C devices that pass a DisplayPort video signal, such as the MacBook and Chromebook Pixel . It's also compatible with Thunderbolt 3 ports.
Unlike some video adapters that take up one of your laptop's USB-C ports to output video, this video adapter features an additional USB-C charge port that supports USB Power Delivery up to 60 watts. This means you can charge your laptop and output video using a single port, by simply connecting the laptop's power adapter to the adapter's USB-C port. It's the perfect solution for laptops that have a limited number of USB-C ports.
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design. It's the perfect accessory to carry with your MacBook or other USB-C computer, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so no matter how you plug it in, the adapter will always connect. This saves you the hassle and embarrassment of struggling with your device when you're trying to deliver a presentation or sharing information.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. The adapter lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display. 4K resolution gives you additional screen space to simplify your approach to detailed work such as editing video and viewing large spreadsheets.
Even if you're not running 4K, the adapter supports high-definition 1080p and lower resolutions, which gives you peace of mind in knowing that this adapter will work with any DP display you need to connect to.
StarTech.com USB C to DisplayPort Adapter with Power Delivery, 4K 60Hz HBR2, USB Type-C to DP 1.2 Monitor/Display Video Converter w/ 60W PD Pass-Through Charging, Thunderbolt 3 Compatible - USB-C Male to DP Female (CDP2DPUCP) - DisplayPort adapter
DisplayPort adapter
USB Power Delivery (60W), 4K60Hz (4096 x 2160) support, plastic housing, HBR2 support, DisplayPort Alternate Mode support, 7.1 audio channel support, 21.6 Gbps data rate
Connectors
24 pin USB-C - male (input)
Connectors (Second End)
20 pin DisplayPort - female (output) , 24 pin USB-C (power only) - female
Displayport 1.2/Thunderbolt 3
3-year warranty
DisplayPort adapter
4.3 cm
Connectors
Displayport 1.2/Thunderbolt 3, HDCP 2.2, HDCP 1.4
Shipping Width
14.5 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
90 g
3-year warranty
D384 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.06
D384 StarTech.com USB-C to VGA Adapter In Stock £24.67
D384 StarTech.com USB-C to VGA Adapter - White In Stock £22.46
D384 StarTech.com USB-C to HDMI Adapter In Stock £16.92
D384 StarTech.com USB-C to HDMI Adapter In Stock £18.98
D384 StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £20.53
D384 StarTech.com USB-C to DisplayPort Adapter In Stock £24.60
D384 StarTech.com USB-C to DP with USB PD In Stock £16.26
D384 StarTech.com USB-C to Mini DisplayPort In Stock £14.77
D384 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.46
D384 StarTech.com USB C to mDP Adapter 12" Cable In Stock £16.43
