Use this adapter to connect two independent displays to a single USB Type-C port. This MST hub lets you connect two DisplayPort monitors to your USB-C computer. MST works on any Windows device with DP alt mode over USB Type-C, such as models of Dell Precision and Dell XPS laptops. The MST hub is powered by the USB-C port, so you don't require an additional power adapter.
This adapter works with USB Type-C devices that pass a DisplayPort video signal and it's also compatible with Thunderbolt 3 ports.
The newest generations of laptops are more portable than ever. Unfortunately, this could mean that you're left with fewer video outputs and confined to a small integrated screen. This MST hub solves these problems by letting you connect two independent displays to a USB-C port on your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. This makes it easier to multitask and increase your productivity - perfect for creating an easy-to-dock hot-desk solution with a wireless keyboard and mouse peripheral set.
The hub also lets you mirror the same image onto multiple displays, for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. 4K is supported by the latest A/V devices and offers four times the resolution of 1080p. Plus, because the MST hub can output high-definition 1080p, the MST hub is perfect for all high-resolution applications such as graphic design and CAD drawing.
With this MST hub, you can use separate DP video adapters to connect HDMI, VGA or DVI displays, for compatibility with all of your existing monitors. The hub supports DP 1.2 enabled systems, for seamless integration with your existing video equipment.
Increase your productivity with multiple monitors
The laptops are more portable than ever. Unfortunately, this could mean that you're left with fewer video outputs and confined to a small integrated screen. This MST hub solves these problems by letting you connect two independent displays to a USB-C port on your computer, which makes multitasking much easier. Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. This makes it easier to multitask and increase your productivity - perfect for creating an easy-to-dock hot-desk solution with a wireless keyboard and mouse peripheral set. The hub also lets you mirror the same image onto multiple displays, for remote viewing applications such as digital signage. -
Astonishing picture quality that won't drain your system resources
MST technology uses your existing video card to minimize the use of system resources while delivering high resolutions. -
Works with any monitor, television or projector
- StarTech.com 2-Port Multi Monitor Adapter, USB-C to 2x DisplayPort 1.2 Video Splitter, USB Type-C to DP MST Hub, Dual 4K 30Hz or 1080p 60Hz, Compatible with Thunderbolt 3, Windows Only - Multi Stream Transport (MSTCDP122DP) - DisplayPort adapter - 24 pin USB-C to DisplayPort - 38.6 m
- USB power, 4K30Hz (3840 x 2160) support, 2560 x 1600 (WQXGA) support 60Hz, HBR2 support, DisplayPort Alternate Mode support, DisplayPort Multi-Stream Transport (MST), 5.1 audio channel support
- Length
- 38.6 m
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- 2 x 20 pin DisplayPort - female (output)
- Displayport 1.2/Thunderbolt 3
- Black
- 3-year warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, TB33A1C
- Length
- 38.6 m
- Black
- 5.8 cm
- 1.4 cm
- 44 g
- Connector
- Displayport 1.2/Thunderbolt 3, FCC, RoHS
- Shipping Width
- 14.3 cm
- Shipping Depth
- 17.2 cm
- Shipping Height
- 3.2 cm
- Shipping Weight
- 133 g
- 3-year warranty
- Designed For
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £12.90 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £10.81 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.78 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £16.38 |
StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub | In Stock | £83.38 |
StarTech.com MST Hub - mDP to 2x DP | In Stock | £57.50 |
StarTech.com MST Hub - 2-Port DisplayPort | In Stock | £58.58 |
StarTech.com mDP 1.2 to HDMI MST Hub | In Stock | £100.48 |
StarTech.com USB-C to HDMI Adapter | In Stock | £23.94 |
StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz | In Stock | £31.86 |
StarTech.com 6ft USB-C to DisplayPort Cable | In Stock | £28.93 |
StarTech.com USB-C to DisplayPort MST Hub - 2-Port | In Stock | £55.32 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £30.91 |
StarTech.com USB-C to 2x HDMI MST Splitter | In Stock | £43.81 |
StarTech.com 3-Port USB C to HDMI MST Hub | In Stock | £83.89 |
StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable | In Stock | £18.38 |
StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K | In Stock | £26.61 |
StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter | In Stock | £14.39 |
StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz | In Stock | £33.46 |
StarTech.com USB C Dual HDMI MST HUB 4K | In Stock | £65.60 |
StarTech.com 3-Port USB-C MST Hub, 4K 60Hz | In Stock | £91.48 |
StarTech.com 2-Port USB-C MST Hub, 4K 60Hz | In Stock | £64.91 |
