StarTech.com USB-C to DisplayPort MST Hub - 2-Port
Quicklinx: CC3RWS00 Mfr#: MSTCDP122DP
£39.44 ex VAT
£47.32 inc VAT
Use this adapter to connect two independent displays to a single USB Type-C port. This MST hub lets you connect two DisplayPort monitors to your USB-C computer. MST works on any Windows device with DP alt mode over USB Type-C, such as models of Dell Precision and Dell XPS laptops. The MST hub is powered by the USB-C port, so you don't require an additional power adapter.
This adapter works with USB Type-C devices that pass a DisplayPort video signal and it's also compatible with Thunderbolt 3 ports.
The newest generations of laptops are more portable than ever. Unfortunately, this could mean that you're left with fewer video outputs and confined to a small integrated screen. This MST hub solves these problems by letting you connect two independent displays to a USB-C port on your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. This makes it easier to multitask and increase your productivity - perfect for creating an easy-to-dock hot-desk solution with a wireless keyboard and mouse peripheral set.
The hub also lets you mirror the same image onto multiple displays, for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. 4K is supported by the latest A/V devices and offers four times the resolution of 1080p. Plus, because the MST hub can output high-definition 1080p, the MST hub is perfect for all high-resolution applications such as graphic design and CAD drawing.
With this MST hub, you can use separate DP video adapters to connect HDMI, VGA or DVI displays, for compatibility with all of your existing monitors. The hub supports DP 1.2 enabled systems, for seamless integration with your existing video equipment.
  • Multitasking Made Easy
    With devices becoming more portable than ever, you can be limited to fewer video outputs and confined to your small integrated screen. This multi-stream transport hub solves that problem by enabling you to connect two separate displays to your USB-C computer, making multitasking much easier. Using this USB-C to dual DisplayPort monitor adapter, you can mirror your display onto additional monitors or stream independent content to each display, which makes it the ideal accessory for travel or hot-desking.
  • Astonishing Picture Quality
    MST technology uses your existing video card to minimize the use of system resources, while delivering UHD 4K resolutions for two monitors or displays simultaneously. With support for HD 1080p and UHD 4K, the dual-monitor splitter is perfect for all high-resolution applications such as graphic design and CAD drawing.
  • Hassle-Free Setup
    Multi-stream transport offers an easy setup, by natively working on any Windows device that supports DP Alt Mode over USB Type-C. This USB-C dual-monitor adapter is Thunderbolt 3 compatible, and offers plug-and-play installation with no drivers or software required. Additionally, this DP MST hub is powered by the USB-C port, meaning no external power cords are necessary. MSTCDP122DP is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
StarTech.com 2-Port Multi Monitor Adapter, USB-C to 2x DisplayPort 1.2 Video Splitter, USB Type-C to DP MST Hub, Dual 4K 30Hz or 1080p 60Hz, Compatible with Thunderbolt 3, Windows Only - Multi Stream Transport (MSTCDP122DP) - DisplayPort adapter - 24 pin USB-C to DisplayPort - 38.6 m
DisplayPort adapter
USB power, 4K30Hz (3840 x 2160) support, 2560 x 1600 (WQXGA) support 60Hz, HBR2 support, DisplayPort Alternate Mode support, DisplayPort Multi-Stream Transport (MST), 5.1 audio channel support
Length
38.6 m
Connector
24 pin USB-C - male (input)
Connector (Second End)
2 x 20 pin DisplayPort - female (output)
Displayport 1.2/Thunderbolt 3
3-year warranty
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, TB33A1C
DisplayPort adapter
Length
38.6 m
5.8 cm
1.4 cm
44 g
Connector
Displayport 1.2/Thunderbolt 3, FCC, RoHS
Shipping Width
14.3 cm
Shipping Depth
17.2 cm
Shipping Height
3.2 cm
Shipping Weight
133 g
3-year warranty
CC3R StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
CC3R StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
CC3R StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
CC3R StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £14.91
CC3R StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £38.03
CC3R StarTech.com MST Hub - mDP to 2x DP In Stock £19.04
CC3R StarTech.com MST Hub - 2-Port DisplayPort In Stock £43.28
CC3R StarTech.com MST Hub - mDP to 4x DP In Stock £47.04
CC3R StarTech.com mDP 1.2 to HDMI MST Hub In Stock £33.29
CC3R StarTech.com USB-C to HDMI Adapter In Stock £15.52
CC3R StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £7.64
CC3R StarTech.com 6ft USB-C to DisplayPort Cable In Stock £18.73
CC3R StarTech.com 2m USB-C to HDMI Cable In Stock £27.94
CC3R StarTech.com USB-C to HDMI - Power Delivery In Stock £23.58
CC3R StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £6.89
CC3R StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.04
CC3R StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £23.05
CC3R StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter In Stock £20.32
CC3R StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.80
CC3R StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £11.44
CC3R StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.89
CC3R StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £16.97
CC3R StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £28.47
CC3R StarTech.com USB C Dual HDMI MST HUB 4K In Stock £24.45
CC3R StarTech.com 3-Port USB-C MST Hub, 4K 60Hz In Stock £29.54
CC3R StarTech.com 2-Port USB-C MST Hub, 4K 60Hz In Stock £25.08
CC3R StarTech.com USB-C Triple DP MST HUB 4K In Stock £29.52
CC3R StarTech.com 6.6ft USB C to DP 1.2 Cable In Stock £31.29
