StarTech.com USB-C to DisplayPort Adapter
Quicklinx: CTW3WS00 Mfr#: CDP2DPW
Colours:
£20.19 ex VAT
£24.22 inc VAT
Connect your MacBook, Chromebook or laptop with USB-C to a DisplayPort monitor or projector. This USB-C to DisplayPort adapter enables you to output DP video and audio from the USB Type-C port on your laptop or other device. The adapter works with USB-C devices that pass a DisplayPort (DP) video signal, such as your MacBook Pro, Chromebook or other USB-C laptop. This enables you to connect your DisplayPort display to your USB-C computer using a DisplayPort cable.
The adapter lets you harness the video capabilities that are built into your computer's USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable.
With this adapter, you can achieve an output resolution of up to 3840 x 2160p at 60Hz, which is perfect for performing high-resolution tasks such as viewing 4K video. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
With its all-white design, this USB-C video adapter is the perfect accessory for your MacBook with USB-C. The compact adapter is lightweight and easy to take with you in your laptop bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
While the adapter looks great next to your Mac and HP ENVY, it also works with any USB-C computer that supports DisplayPort Alt Mode, such as your Dell XPS or other Windows laptop.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work, saving you the hassle and embarrassment of adjusting your device when you're trying to deliver a presentation.
Your USB-C device must support DisplayPort over USB-C (DP Alt Mode) to work with this adapter. This adapter outputs a single-mode DisplayPort signal and will not work with additional video adapters such as DisplayPort to HDMI, DisplayPort to VGA or DisplayPort to DVI adapters.
  • Ultra HD 4K & 8K Resolution
    The adapter lets you harness the video capabilities that are built into your computer's USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable. With this adapter, you can also achieve an output resolution of up to 7680x4320 at 30Hz, which is perfect for performing high-resolution tasks such as viewing 8K video. Plus, the DP 1.4 adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications while future-proofing for 8K implementation.
  • Ultimate Portability
    This USB Type-C video adapter is highly portable with a small footprint and lightweight design that's easy to tuck into your laptop bag. The adapter is the perfect accessory for connecting your MacBook Pro or Dell XPS to a DisplayPort monitor or display in BYOD (Bring Your Own Device) applications at the office.
  • Hassle-Free Connection with USB Type-C
    This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work, saving you the hassle and embarrassment of adjusting your device when you're trying to deliver a presentation. The CDP2DPW is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes: • Your USB-C device must support DisplayPort over USB-C (DP alt mode) to work with this adapter • This adapter outputs a single-mode DisplayPort signal and will not work with additional video adapters such as DisplayPort to HDMI, DisplayPort to VGA or DisplayPort to DVI adapters
StarTech USB C to DisplayPort Adapter - 4K 60Hz - White - USB 3.1 Type-C to DisplayPort Adapter - USB C Video Adapter (CDP2DPW) - external video adapter - white
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1200
Interfaces Details
DisplayPort
3.7 cm 1.4 cm
Cable Length
18 cm
Enclosure Colour
White
3-year warranty
Bus Type
USB-C
Max Resolution
1920 x 1200 at 60 Hz
Interfaces Details
DisplayPort
HD/4k Ready, 7.1 channel surround sound ready, Thunderbolt 3 compatible
- 18 cm
FCC, RoHS
3.7 cm
1.4 cm
Cable Length
18 cm
26 g
Enclosure Colour
White
Limited warranty - 3 years
CTW3 StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.24
CTW3 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
CTW3 StarTech.com USB-C to HDMI Adapter In Stock £15.93
CTW3 StarTech.com USB-C to HDMI Adapter In Stock £15.52
CTW3 StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £7.64
CTW3 StarTech.com 6ft USB-C to DisplayPort Cable In Stock £18.72
CTW3 StarTech.com 2m USB-C to HDMI Cable In Stock £27.94
CTW3 StarTech.com USB-C to HDMI - Power Delivery In Stock £23.48
CTW3 StarTech.com USB-C to DisplayPort Adapter In Stock £22.59
CTW3 StarTech.com USB-C to DisplayPort Adapter In Stock £20.19
CTW3 StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.04
CTW3 StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £23.05
CTW3 StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter In Stock £20.32
CTW3 StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.80
CTW3 StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £11.44
CTW3 StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.89
CTW3 StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £16.97
CTW3 StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £28.47
CTW3 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.72
CTW3 StarTech.com 6.6ft USB C to DP 1.2 Cable In Stock £31.29
