This USB-C to DisplayPort adapter lets you connect your USB Type-C or Thunderbolt 3 device to a DisplayPort display, providing you with a convenient, high-performance solution. The adapter features USB Power Delivery so you can power and charge your devices while outputting Ultra HD video.
Power & Video with USB Power Delivery
This USB-C display adapter supports USB Power Delivery up to 60 watts and features an additional USB-C port so you can charge your laptop or tablet using its USB-C power adapter. -
IT Pro Performance
This adapter features a unique video signal booster which amplifies the signal and ensures reliable performance, even with lower quality cables. The amplifier also increases the max. supported DP cable length compared to other brands. -
Incredible 8K Picture Quality
Delivering cutting-edge picture quality, this 8K DisplayPort 1.4 adapter supports UHD resolutions up to 7680x4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging. The DisplayPort dongle is also backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation. -
Ideal for Travel
This lightweight display adapter is highly portable, with a small-footprint design. It's the perfect accessory for your MacBook, Microsoft Surface Book or other USB-C (or Thunderbolt 3) device, fitting perfectly into your carrying case. CDP2DP14UCPB is backed by a 3-year StarTech.com warranty and free lifetime technical support. Note: • Your USB-C device must support DisplayPort Alternate Mode to work with this adapter. • To achieve 8K resolutions, your source and your destination must support DisplayPort 1.4.
- StarTech.com USB C to DisplayPort Adapter with Power Delivery, 8K 60Hz/4K 120Hz USB Type C to DP 1.4 Monitor Video Converter w/60W PD Pass-Through Charging, HBR3, Thunderbolt 3 Compatible - USB-C Male to DP Female (CDP2DP14UCPB) - USB / DisplayPort adapter
- 8K support, active adapter, up to 60 Watts of power delivery, High Bit Rate 3 (HBR3), 7.1 audio channel support
- Connectors
- 24 pin USB-C - male (input)
- Connectors (Second End)
- 20 pin DisplayPort - female (output) , 24 pin USB-C - female (output)
- Thunderbolt 3 / DisplayPort 1.4
- Black
- 3-year warranty
- Black
- Connectors
- Thunderbolt 3 / DisplayPort 1.4, FCC, RoHS, REACH
- 3-year warranty
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £10.00 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £8.54 |
StarTech.com 1m 3.3ft DisplayPort 1.4 Cable | In Stock | £6.89 |
StarTech.com 2m 6.6ft DisplayPort 1.4 Cable | In Stock | £11.86 |
StarTech.com 3m 9.8ft DisplayPort 1.4 Cable | In Stock | £23.75 |
StarTech.com 5m DisplayPort 1.4 Cable | In Stock | £30.35 |
