StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz
Quicklinx: FP9GWS00 Mfr#: CDP2DP14UCPB
£27.78 ex VAT
£33.33 inc VAT
This USB-C to DisplayPort adapter lets you connect your USB Type-C or Thunderbolt 3 device to a DisplayPort display, providing you with a convenient, high-performance solution. The adapter features USB Power Delivery so you can power and charge your devices while outputting Ultra HD video.
  • Power & Video with USB Power Delivery
    This USB-C display adapter supports USB Power Delivery up to 60 watts and features an additional USB-C port so you can charge your laptop or tablet using its USB-C power adapter.
  • IT Pro Performance
    This adapter features a unique video signal booster which amplifies the signal and ensures reliable performance, even with lower quality cables. The amplifier also increases the max. supported DP cable length compared to other brands.
  • Incredible 8K Picture Quality
    Delivering cutting-edge picture quality, this 8K DisplayPort 1.4 adapter supports UHD resolutions up to 7680x4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging. The DisplayPort dongle is also backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
  • Ideal for Travel
    This lightweight display adapter is highly portable, with a small-footprint design. It's the perfect accessory for your MacBook, Microsoft Surface Book or other USB-C (or Thunderbolt 3) device, fitting perfectly into your carrying case. CDP2DP14UCPB is backed by a 3-year StarTech.com warranty and free lifetime technical support. Note: • Your USB-C device must support DisplayPort Alternate Mode to work with this adapter. • To achieve 8K resolutions, your source and your destination must support DisplayPort 1.4.
StarTech.com USB C to DisplayPort Adapter with Power Delivery, 8K 60Hz/4K 120Hz USB Type C to DP 1.4 Monitor Video Converter w/60W PD Pass-Through Charging, HBR3, Thunderbolt 3 Compatible - USB-C Male to DP Female (CDP2DP14UCPB) - USB / DisplayPort adapter
8K support, active adapter, up to 60 Watts of power delivery, High Bit Rate 3 (HBR3), 7.1 audio channel support
Connectors
24 pin USB-C - male (input)
Connectors (Second End)
20 pin DisplayPort - female (output) , 24 pin USB-C - female (output)
Thunderbolt 3 / DisplayPort 1.4
3-year warranty
Connectors
Thunderbolt 3 / DisplayPort 1.4, FCC, RoHS, REACH
3-year warranty
FP9G StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £13.69
FP9G StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.52
FP9G StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £8.20
FP9G StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £6.92
FP9G StarTech.com 2m 6.6ft DisplayPort 1.4 Cable In Stock £8.49
FP9G StarTech.com 3m 9.8ft DisplayPort 1.4 Cable In Stock £17.22
FP9G StarTech.com 5m DisplayPort 1.4 Cable In Stock £29.60
FP9G StarTech.com USB C Video Adapter 4K 60Hz In Stock £40.68
