This USB-C to DisplayPort adapter lets you connect your USB Type-C or Thunderbolt 3 device to a DisplayPort monitor or display, providing you with a convenient, high-performance solution. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
Supporting four times the resolution of 4K, this 8K DisplayPort 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
With cutting-edge picture quality, this adapter is ideal for: Displaying crisp digital signage walls; Creating eye-catching visuals for photography and videography; Streaming high-resolution, life-like content.
The DisplayPort dongle is also backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
This lightweight display adapter is highly portable, with a small-footprint design. It's the perfect accessory for your MacBook, Microsoft Surface Book or other USB-C (or Thunderbolt 3) device, fitting perfectly into your carrying case.
To ensure easy operation, this USB C to DisplayPort adapter supports plug-and-play installation, removing the need for additional software or drivers.
Your USB-C device must support DP Alt Mode to work with this adapter. This product will not work with the Samsung S8 smartphone. For hassle-free compatibility with the S8 use CDP2DP.
Incredible 8K Picture Quality
Supporting four times the resolution of 4K, this 8K DisplayPort 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320; and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging. With cutting-edge picture quality, this adapter is ideal for: • Displaying crisp digital signage walls • Creating eye-catching visuals for photography and videography • Streaming high-resolution, life-like content The DisplayPort dongle is also backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation. -
Ideal for Travel
This lightweight display adapter is highly portable, with a small-footprint design. It's the perfect accessory for your MacBook, Microsoft Surface Book or other USB-C (or Thunderbolt 3) device, fitting perfectly into your carrying case. -
Hassle-Free Setup
To ensure easy operation, this USB C to DisplayPort adapter supports plug-and-play installation, removing the need for additional software or drivers. CDP2DP14B is backed by a 3-year StarTech.com warranty and free lifetime technical support. Note: • Your USB-C device must support DP Alt Mode to work with this adapter. • To achieve 8K resolutions, your source and your destination must support DisplayPort 1.4. • This product will not work with the Samsung S8 smartphone. For hassle-free compatibility with the S8 we recommend using CDP2DP .
- StarTech USB C to DisplayPort Adapter, 8K/5K/4K USB Type C to DP 1.4 Alt Mode Video Converter, HBR3/DSC/HDR, 8K 60Hz, Thunderbolt 3 Compatible DisplayPort 1.4 Monitor Display Adapter - 8K USB-C to DP Adapter (CDP2DP14B) - DisplayPort adapter - USB-C to DisplayPort
- 1080p support, 4K120Hz support, 8K60Hz (7680 x 4320) support, 5K60Hz support, plastic housing, Ultra HD (4K) support, DisplayPort Alternate Mode support, 5K support, HBR3 support, HDR support, 7.1 audio channel support, 32.4 Gbps data rate, Display Stream Compression (DSC)
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- 20 pin DisplayPort - female (output)
- Thunderbolt 3 / DisplayPort 1.4
- Black
- 3-year warranty
- Designed For
- P/N: TB4CDOCK
- Black
- 6 cm
- 2.35 cm
- 1.5 cm
- 34 g
- Connector
- Thunderbolt 3 / DisplayPort 1.4, FCC, RoHS, HDCP 2.2, HDCP 1.4
- Shipping Width
- 20 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 44 g
- 3-year warranty
- Designed For
- P/N: TB4CDOCK
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.24 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.58 |
StarTech.com 1m 3.3ft DisplayPort 1.4 Cable | In Stock | £6.89 |
StarTech.com 2m 6.6ft DisplayPort 1.4 Cable | In Stock | £11.86 |
StarTech.com 3m 9.8ft DisplayPort 1.4 Cable | In Stock | £23.75 |
StarTech.com 5m DisplayPort 1.4 Cable | In Stock | £30.35 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £13.66 |
