Add a parallel port through your laptop or desktop computer's USB-C port, and connect to a DB25 parallel printer. This USB-C to parallel printer cable allows you to connect your USB-C enabled laptop or desktop computer to a DB25 printer.
A cost-effective and reliable solution, the USB to DB25 adapter saves you the expense of replacing a parallel printer for the sake of USB compatibility. It turns an available USB-C port on your laptop or desktop computer into a DB25 female parallel port, allowing you to connect a DB25 printer to your computer as if the necessary parallel port was built-in.
The printer cable is supported by a broad range of operating systems, including Windows, Linux, and macOS, which makes it easy to integrate into mixed OS environments. It supports plug-and-play installation, saving you time and hassle.
The printer cable is USB powered, so there's no need for an external power adapter.
- StarTech.com USB C to Parallel Printer Cable - DB25 Female Port for IEEE1284 Printers - Bus Powered - Printer Cable Adapter - USB to DB25 (ICUSBCPLLD25) - USB / parallel cable - 24 pin USB-C to DB-25 - 183 cm
- Chipset Prolific PL2305
- Length
- 183 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 25 pin D-Sub (DB-25) - female
- 2-year warranty
- Length
- 183 cm
- 100 g
- Connector
- FCC, RoHS, WEEE, RCM
- 2-year warranty
