This USB C to HDMI adapter lets you extend your desktop by adding four independent HDMI monitors or displays to your computer using a single USB Type-C port.
This USB-C to 4 HDMI adapter features four video outputs, boosting your productivity by giving you more screen space to work from. With multiple displays you have the freedom to access multiple applications at the same time and reference material on one display while you compose on the other. Use the USBC to HDMI multi-monitor adapter to extend or mirror your displays, or create an eye-catching video wall.
This quad monitor adapter lets you harness the video capabilities from your computer or laptop's USB-C connection, to deliver high-definition resolutions up to 1920x1080 (1080p) on all four ports. The adapter also supports 2-channel audio through HDMI.
The USB Type-C to HDMI display adapter converter is equipped with a 1.6 ft. (0.5 m) attached USB-C cable that provides added distance between the adapter and your host device, ensuring a flexible setup. It also supports an automatic driver installation for ease of use.
The external video adapter is bus-powered, with no external power required.
The Multi-Monitor Assistant application provides a user interface that assists users with multitasking, and allows you to quickly switch from monitor to monitor. It enables additional features, assisting users with dragging and dropping, optional zooming, split scaling and cascading windows to the main display, as well as creating a dynamic video or matrix wall.
All four monitors must be of the same size and resolution in order to achieve a video wall.
The adapter is only capable of mirroring up to two additional displays.
Increase Your Productivity
This USB-C to 4 HDMI adapter features four video outputs, boosting your productivity by giving you more screen space to work from. With multiple displays you have the freedom to access multiple applications at the same time and reference material on one display while you compose on the other. Use the USBC to HDMI multi-monitor adapter to extend or mirror your displays, or create an eye-catching video wall. -
High-Definition Video & Audio
This quad monitor adapter lets you harness the video capabilities from your computer or laptop's USB-C connection, to deliver high-definition resolutions up to 1920x1080 (1080p) on all four ports. The adapter also supports 2-channel audio through HDMI. -
Easy Setup
The USB Type-C to HDMI display adapter converter is equipped with a 1.6 ft. (0.5 m) attached USB-C cable that provides added distance between the adapter and your host device, ensuring a flexible setup. It also supports an automatic driver installation for ease of use. The external video adapter is bus-powered, with no external power required. -
Multi-Monitor Assistant Software
The Multi-Monitor Assistant application provides a user interface that assists users with multitasking, and allows you to quickly switch from monitor to monitor. It enables additional features, assisting users with dragging and dropping, optional zooming, split scaling and cascading windows to the main display, as well as creating a dynamic video or matrix wall. USBC2HD4 is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: All four monitors must be of the same size and resolution in order to achieve a video wall. The adapter is only capable of mirroring up to two additional displays.
- StarTech.com USB C to 4 HDMI Adapter, External Video & Graphics Card, USB Type-C to Quad HDMI Monitor Display Adapter Dongle, 1080p 60Hz, Video Converter, Supports Windows - USB-C Multi Monitor Adapter - adapter cable - HDMI / USB - 50 cm
- Cable
- Adapter cable - HDMI / USB
- Max Output Resolution
- 1920 x 1080 - 60 Hz
- Length
- 50 cm
- Space grey
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 4 x HDMI - female
- 1080p support 60Hz
- 2-year warranty
- Cable Type
- Adapter cable 1080p support 60Hz
- Interface Supported
- HDMI / USB
- Length
- 50 cm
- USB powered, aluminium casing
- Space grey
Adapters & Converters
- 1920 x 1080
- Refresh Rate
- 60 Hz
- OS Required
- Windows 10
- Connector
- 4 x 19 pin HDMI Type A - female
- FCC, RoHS
- 8.01 cm
- 10.1 cm
- 1.6 cm
- 171 g
- Shipping Width
- 20.7 cm
- Shipping Depth
- 14.4 cm
- Shipping Height
- 3.8 cm
- Shipping Weight
- 285 g
- Limited warranty - 2 years
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.37 |
StarTech.com 2m/6.6 ft Premium High Speed HDMI Cable with Ethernet | In Stock | £16.62 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £16.02 |
