StarTech.com USB-C Speakerphone Dock
Quicklinx: HHX1WS00 Mfr#: DKTBRSPMPD
£78.85 ex VAT
£94.62 inc VAT
This USB Type-C Conference Speaker Mini Dock features a speakerphone, HDMI/VGA video output, USB-C PD pass-through/data, a USB-A x2 hub, a built-in USB-C host cable, and tap/touch buttons with LED indicators. It simplifies a workstation setup, converting any desk into a teleconferencing space. The dock features HDMI or VGA single-video output. It has 2 USB-A ports and a USB-C port with the option for Power Delivery (PD) pass-though.. The Conference Speaker Dock connects to the host device, using a built-in wraparound 22 in. (56 cm) USB-C host cable. Connect this host cable to a USB-C or Thunderbolt 3/4 port.
  • Unified Collaboration Platform Compatibility
    The Speakerphone Dock is optimized for use with Unified Communications (UC) platforms, such as Microsoft Teams, Zoom, Google Meet, etc. The dock features buttons that intuitively control functions within the UC platform: • Call Button - Tap to receive and accept an incoming call. • Hang up Button - Tap to disconnect from the current call or to reject an incoming call. • +/- Volume Buttons - Tap to adjust the system volume. • Mute Button - Tap to disable the built-in microphone. The dock is optimized for Microsoft Teams and fully compatible with other UC/softphone applications including Zoom, Skype, and Google Meet.
  • Conference Speaker and Omnidirectional Microphones
    Capture voices from up to 7.5ft (2.3m) away, using the dual-omnidirectional microphones (100Hz to 10kHz) with echo cancellation and noise reduction. The microphones are ideal for capturing audio in mid-size meeting rooms (6-8 people) or from any location in a home office room. The speakers deliver 89dB (100Hz - 20kHz) distortion-free high-definition audio.
  • Easy Deployment
    The speaker dock features docking station connectivity options in a quick-to-deploy format. Connect an HDMI or VGA enabled display device for single-video output. The HDMI video output supports resolutions up to 4K 60Hz. The VGA video output supports resolutions up to 1080p 60Hz. Power and charge the connected laptop by connecting the host computer's USB-C power adapter to the USB-C PD 3.0 pass-though port. Alternatively, power the speaker dock with bus power. In this configuration, the USB-C PD port can be used to connect a USB 3.2 Gen 1 (5Gbps) peripheral. The dock also features a built-in 22 in. (56 cm) cable to provide extended reach that reduces port/connector strain on 2-in-1 devices like the Surface Pro 7/8, or when used with laptops on a riser stand. The docking station supports Windows, macOS, and Chrome OS. Connect to Thunderbolt 3/4 and USB Type-C laptops from HP, Lenovo, Dell, and Apple.
  • Compact and Portable
    Integrated wrap-around cable management enables the cable to be tucked away to prevent tangling during transit. The small desktop foot print is ideal for hybrid travel use between the office, and work-from-home virtual meetings.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : Setup and save custom windows layouts. •Text | USB Event Monitoring Utility : Track and log connected USB devices.
StarTech.com USB-C Conference Speaker Mini Dock, Portable Boardroom Speaker and Multiport Adapter, USB-C to VGA or 4K 60Hz HDMI, 2x USB-A (5Gbps) Hub, Mic/Speaker - Teams/Zoom/Softphone Speakerphone (DKTBRSPMPD) - mini-dock - USB-C / Thunderbolt 3 / Thunderbolt 4 - HDMI, VGA
Mini-dock
Docking Interface
Video Interfaces
HDMI, VGA
13 cm x 13 cm x 3.6 cm
600 g
Space grey
Audio Output
Speaker(s)
3-year warranty
Mini-dock
13 cm
13 cm
3.6 cm
600 g
Enclosure Colour
Space grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz (HDMI only) , 1920 x 1200 - 60 Hz (VGA only)
Audio
Audio Output
Speaker(s)
USB 3.2 Gen 1
1 x display / video - HDMI output - 19 pin HDMI Type A , Display / video - VGA output - 15 pin D-Sub (DB-15) , 2 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 1 with Power Delivery (100 W) - 24 pin USB-C
Input Device
Two microphones, control buttons
1 x USB-C 3.2 Gen 1 cable - integrated - 56 cm
5Gbps data transfer, USB-C powered, plastic housing, DisplayPort Alt Mode, laptop power charging support, mute button, volume control
USB Power Delivery 3.0, UASP (USB Attached SCSI Protocol), RoHS, WEEE, FCC, RCM, Microsoft Teams certified, Zoom certification
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Google Chrome OS, Linux 3.5.x or later LTS versions only, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Width
20 cm
Shipping Depth
20 cm
Shipping Height
4.5 cm
HHX1 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.80
HHX1 StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.48
HHX1 StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
HHX1 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
HHX1 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.75
HHX1 StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.98
HHX1 StarTech.com USB-C to RJ9 Adapter/Dongle In Stock £27.45
