This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C laptop to a VGA, DVI, HDMI or Mini DisplayPort (mDP) display. It features USB Power Delivery, so you can power your laptop while outputting video using the same USB-C port.
This USB-C adapter supports USB Power Delivery up to 95 watts and features an additional USB-C port. You can charge your laptop using its USB-C power adapter, even while you output video. Many laptops support charging through a USB-C port with Power Delivery, check your specifications to confirm compatibility.
Carry one adapter instead of four. This versatile 4-in-1 monitor adapter lets you connect your USB-C laptop to any display. With its durable aluminum enclosure and a magnetic retainer that secures the breakout cable in place while you're not using it, the adapter is rugged enough to carry in your travel bag.
The HDMI and mDP outputs support UHD 4K resolutions, providing four times the picture quality of high-definition 1080p. All of the outputs (HDMI, mDP, VGA, DVI) support high-definition resolutions up to 1920 x 1200. The adapter is compatible with USB-C DP Alt Mode devices.
The USB-C adapter has a Space Gray trim and built-in USB-C cable designed to match your Space Gray MacBook, or MacBook Pro.
- StarTech.com USB C Multiport Video Adapter, 4K 60Hz UHD Portable 5-in-1 USB Type C to HDMI 2.0, Mini DisplayPort, VGA or DVI (1080p), 95W PD Passthrough, Cable Management, Aluminum Adapter - 5-in-1 USB-C Converter (CDPVDHMDPDP) - external video adapter - space grey
- External video adapter
- Bus Type
- USB-C
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI (Dual-Link): 1920 x 1200 at 60 Hz / DisplayPort: 4096 x 2160 at 60 Hz / HDMI: 4096 x 2160 at 24 Hz / VGA: 1920 x 1200 at 60 Hz
- Interfaces Details
- HDMI (female connector) , VGA (female connector) , DVI-D (dual link) (female connector) , Mini DisplayPort (female connector)
- 10.9 cm x 5.7 cm x 1.8 cm
- Enclosure Colour
- Space grey
- 3-year warranty
- Bus Type
- USB-C
- Max Resolution
- 4096 x 2160 at 60 Hz
- 7.1 channel surround sound ready
- Cables Included
- USB-C cable - 10.1 cm
- DisplayPort 1.2, FCC
- 10.9 cm
- 5.7 cm
- 1.8 cm
- 80 g
- Shipping Weight
- 100 g
- Enclosure Colour
- Space grey
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 0 - 95%
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.28 |
StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter | In Stock | £21.24 |
StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.35 |
StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £12.14 |
StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M | In Stock | £19.65 |
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter | In Stock | £7.58 |
StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black | In Stock | £32.48 |
StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI | In Stock | £23.42 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £18.32 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £13.32 |
StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter | In Stock | £19.01 |
StarTech.com USB C to HDMI Adapter 4K 60Hz | In Stock | £12.26 |
StarTech.com USB C Video Adapter 4K 60Hz | In Stock | £41.94 |
StarTech.com USB C Video Adapter 4K 60Hz | In Stock | £42.89 |
