StarTech.com USB-C Multiport Video Adapter 4-in-1 - 95W Power Delivery - Space Gray - 4K 60Hz
Quicklinx: F2G6WS00 Mfr#: CDPVDHMDPDP
£67.25 ex VAT
£80.70 inc VAT
This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C laptop to a VGA, DVI, HDMI or Mini DisplayPort (mDP) display. It features USB Power Delivery, so you can power your laptop while outputting video using the same USB-C port.
This USB-C adapter supports USB Power Delivery up to 95 watts and features an additional USB-C port. You can charge your laptop using its USB-C power adapter, even while you output video. Many laptops support charging through a USB-C port with Power Delivery, check your specifications to confirm compatibility.
Carry one adapter instead of four. This versatile 4-in-1 monitor adapter lets you connect your USB-C laptop to any display. With its durable aluminum enclosure and a magnetic retainer that secures the breakout cable in place while you're not using it, the adapter is rugged enough to carry in your travel bag.
The HDMI and mDP outputs support UHD 4K resolutions, providing four times the picture quality of high-definition 1080p. All of the outputs (HDMI, mDP, VGA, DVI) support high-definition resolutions up to 1920 x 1200. The adapter is compatible with USB-C DP Alt Mode devices.
The USB-C adapter has a Space Gray trim and built-in USB-C cable designed to match your Space Gray MacBook, or MacBook Pro.
StarTech.com USB C Multiport Video Adapter, 4K 60Hz UHD Portable 5-in-1 USB Type C to HDMI 2.0, Mini DisplayPort, VGA or DVI (1080p), 95W PD Passthrough, Cable Management, Aluminum Adapter - 5-in-1 USB-C Converter (CDPVDHMDPDP) - external video adapter - space grey
External video adapter
Bus Type
USB-C
Max Resolution
4096 x 2160
Max Resolution Details
DVI (Dual-Link): 1920 x 1200 at 60 Hz / DisplayPort: 4096 x 2160 at 60 Hz / HDMI: 4096 x 2160 at 24 Hz / VGA: 1920 x 1200 at 60 Hz
HDMI (female connector) , VGA (female connector) , DVI-D (dual link) (female connector) , Mini DisplayPort (female connector)
10.9 cm x 5.7 cm x 1.8 cm
Enclosure Colour
Space grey
3-year warranty
Bus Type
USB-C
Max Resolution
7.1 channel surround sound ready
USB-C cable - 10.1 cm
FCC, DisplayPort 1.2
10.9 cm
5.7 cm
1.8 cm
80 g
Shipping Weight
100 g
Enclosure Colour
Space grey
Limited warranty - 3 years
45 °C
0 - 95%
F2G6 StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £8.48
F2G6 StarTech.com 10 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £10.61
F2G6 StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £19.65
F2G6 StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £10.32
F2G6 StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £11.17
F2G6 StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £13.57
F2G6 StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £13.11
F2G6 StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £12.40
F2G6 StarTech.com 3m (10 ft) White Mini DisplayPort Cable - M/M In Stock £16.09
F2G6 StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £19.11
F2G6 StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £25.02
F2G6 StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £33.81
F2G6 StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £25.52
F2G6 StarTech.com mDP to HDMI or VGA Converter In Stock £18.47
F2G6 StarTech.com mDP to HDMI or VGA Converter In Stock £13.32
F2G6 StarTech.com mini DisplayPort to VGA DVI or HDMI Adapter In Stock £27.07
Stock Status: In stock
