StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD
Quicklinx: FTWVWS00 Mfr#: CDP2MDPVGA
Length: 15.24m
Hurry, only 1 left in stock!
£12.55 ex VAT
£15.06 inc VAT
  • Higher contrast & vivid colors
    With support for HDR and 4K 60Hz, the USB C multiport video adapter lets you enjoy higher contrast ratios and vivid colors providing a crystal-clear video output.
  • Flexible video output
    Create a workspace with flexible display options with this?USB C 2 in 1 adapter that lets you connect your?USB C device to a VGA or Mini DisplayPort monitor.
  • Tested for guaranteed compatibility
    USB Type C video adapter can be used with any USB C or Thunderbolt 3 laptop or tablet. Tested and engineered to work with HP, Dell, MacBook Pro, Lenovo, iPad Pro, Surface, Chromebook, Windows, macOS and ChromeOS as well as 50+ monitors, projectors and large format displays.
  • Two-in-one video connectivity with travel in mind
    Avoid the hassle of carrying different adapters, with a?2-in-1?USB-C monitor adapter.?The multiport adapter features both Mini?DP?and VGA outputs, you can conveniently connect your laptop to any?mDP or VGA-equipped?display. The?adapter?features a durable aluminum enclosure and can withstand being carried in your travel bag.
  • Astonishing 4K picture quality?and HDR
    The?Mini DisplayPort?output on this?USB-C video?adapter?lets you harness the audio and?video?capabilities that are built into your computer's?USB-C?connection,?delivering?the astonishing quality of UHD to your?4K 60Hz?display. Plus, the VGA output supports HD resolutions up to 1920 x 1080, ensuring you won't have to sacrifice picture quality when connected to a VGA monitor or projector. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
  • Stylish connectivity for your MacBook, MacBook Pro, or any Laptop
    The?USB-C display adapter?has a Space Gray housing and built-in?USB-C?cable designed to match your Space Gray MacBook or MacBook Pro. The?adapter?is compatible with?USB-C DP?Alt Mode devices.
StarTech.com USB C Multiport Video Adapter, USB-C to 4K 60Hz Mini DisplayPort 1.2 or 1080p VGA Monitor Adapter, USB Type-C 2-in-1 MDP HBR2 HDR/VGA Display Converter, Works w/ Thunderbolt 3 - USB-C 2 in 1 Adapter (CDP2MDPVGA) - video adapter - 15.24 m
Video adapter
4K support, HDR support
Length
15.24 m
Connectors
24 pin USB-C - male
Connectors (Second End)
15 pin HD D-Sub (HD-15) - female , Mini DisplayPort - female
DisplayPort 1.2
Space grey
3-year warranty
Video adapter
Length
15.24 m
Space grey
4.4 cm
1.5 cm
50 g
Connectors
24 pin USB-C - male
DisplayPort 1.2, FCC, RoHS, WEEE, REACH
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
50 g
3-year warranty
Length: 15.24m
