High Dynamic Range Aluminum 6" (15.24 cm) Built-In Cable. This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C laptop to an HDMI or DisplayPort display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
Two-in-One Video Connectivity with Travel in Mind
Avoid the hassle of carrying different adapters, with a 2-in-1 USB-C monitor adapter. The multiport adapter features both HDMI and DisplayPort outputs, so you can conveniently connect your laptop to any HDMI or DP-equipped display, using this multiport adapter.
The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag.
Astonishing 4K Picture Quality and HDR
The HDMI and DisplayPort outputs on this USB-C video adapter lets you harness the audio and video capabilities that are built into your computer's USB-C connection, delivering the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
Stylish Connectivity for Your MacBook, MacBook Pro, or Any Laptop
The USB C display adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices.
CDP2DPHD is backed by a 3-year StarTech.com warranty and free lifetime technical support.
Note: This adapter only supports a single display - you are not able to output DisplayPort and HDMI video simultaneously.
Avoid the hassle of carrying different adapters, with a 2-in-1?USB-C monitor adapter.?The multiport adapter features both?HDMI and DisplayPort?outputs, so you can conveniently connect your laptop to any?HDMI or DP-equipped display, using this?multiport?adapter. The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag. -
Astonishing 4K Picture Quality?and HDR
The?HDMI and DisplayPort?outputs on this?USB-C video?adapter?lets you harness the audio and video capabilities that are built into your computer's?USB-C?connection,?delivering?the astonishing quality of UHD to your?4K 60Hz?display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging. -
The USB C display adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices. CDP2DPHD?is backed by a 3-year StarTech.com warranty and free lifetime technical support. Note: This adapter only supports a single display - you are not able to output DisplayPort and HDMI video simultaneously.
- Startech USB C Multiport Video Adapter, 4K 60Hz USB-C to HDMI 2.0 or DisplayPort 1.2 Monitor Adapter, USB Type-C 2-in-1 Display Converter HDMI/DP HBR2 HDR, Thunderbolt 3 Compatible - USB-C 2 in 1 Adapter (CDP2DPHD) - adapter - DisplayPort / HDMI - 20.5 cm
- Cable
- Adapter - DisplayPort / HDMI
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Cable Length
- 20.5 cm
- Space grey
- Connectors
- USB-C - male (input)
- Connectors (Second End)
- HDMI - female (output) , DisplayPort - female (output)
- Displayport 1.2/Thunderbolt 3
- 4K support, active adapter
- 3-year warranty
- Cable Type
- Adapter 4K support, active
- Interface Supported
- Jacket Material
- Aluminium
- Cable Length
- 20.5 cm
- HDR support, HBR2 audio support, multi-channel audio, DisplayPort Alternate Mode support, Parade PS8338 chipset, ITE Tech IT6563 chipset
- Space grey
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- Connectors
- 24 pin USB-C - male (input)
- 19 pin HDMI Type A - female (output) , 20 pin DisplayPort - female (output)
- FCC, RoHS, WEEE, REACH, RCM
- 6.2 cm
- 1.5 cm
- 48 g
- Shipping Width
- 17.3 cm
- Shipping Depth
- 8 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 70 g
- Limited warranty - 3 years
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £16.00 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £20.46 |
StarTech.com 1m 3.3ft DisplayPort 1.4 Cable | In Stock | £6.89 |
StarTech.com 2m 6.6ft DisplayPort 1.4 Cable | In Stock | £11.86 |
StarTech.com 3m 9.8ft DisplayPort 1.4 Cable | In Stock | £23.75 |
StarTech.com 5m DisplayPort 1.4 Cable | In Stock | £30.35 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £13.72 |
StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD | In Stock | £11.46 |
StarTech.com USB C Multiport Video Adapter - HDMI or Mini DisplayPort -HDR 4K Display Adapter | In Stock | £12.49 |
