StarTech.com USB C Multiport Video Adapter - HDMI or DisplayPort - HDR 4K60 - Display Adapter
Quicklinx: FVKRWS00 Mfr#: CDP2DPHD
Length: 20.5cm
£33.34 ex VAT
£40.00 inc VAT
High Dynamic Range Aluminum 6" (15.24 cm) Built-In Cable. This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C laptop to an HDMI or DisplayPort display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
Two-in-One Video Connectivity with Travel in Mind
Avoid the hassle of carrying different adapters, with a 2-in-1 USB-C monitor adapter. The multiport adapter features both HDMI and DisplayPort outputs, so you can conveniently connect your laptop to any HDMI or DP-equipped display, using this multiport adapter.
The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag.
Astonishing 4K Picture Quality and HDR
The HDMI and DisplayPort outputs on this USB-C video adapter lets you harness the audio and video capabilities that are built into your computer's USB-C connection, delivering the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
Stylish Connectivity for Your MacBook, MacBook Pro, or Any Laptop
The USB C display adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices.
CDP2DPHD is backed by a 3-year StarTech.com warranty and free lifetime technical support.
Note: This adapter only supports a single display - you are not able to output DisplayPort and HDMI video simultaneously.
  • Two-in-One Video Connectivity with Travel in Mind
    Avoid the hassle of carrying different adapters, with a 2-in-1?USB-C monitor adapter.?The multiport adapter features both?HDMI and DisplayPort?outputs, so you can conveniently connect your laptop to any?HDMI or DP-equipped display, using this?multiport?adapter. The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag.
  • Astonishing 4K Picture Quality?and HDR
    The?HDMI and DisplayPort?outputs on this?USB-C video?adapter?lets you harness the audio and video capabilities that are built into your computer's?USB-C?connection,?delivering?the astonishing quality of UHD to your?4K 60Hz?display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
  • Stylish Connectivity for Your MacBook, MacBook Pro, or Any Laptop
    The USB C display adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices. CDP2DPHD?is backed by a 3-year StarTech.com warranty and free lifetime technical support. Note: This adapter only supports a single display - you are not able to output DisplayPort and HDMI video simultaneously.
StarTech.com USB C Multiport Video Adapter, 4K 60Hz USB-C to HDMI 2.0 or DisplayPort 1.2 Monitor Adapter, USB Type-C 2-in-1 Display Converter HDMI/DP HBR2 HDR, Thunderbolt 3 Compatible - USB-C 2 in 1 Adapter (CDP2DPHD) - adapter - DisplayPort / HDMI - 20.5 cm
Cable
Adapter - DisplayPort / HDMI
Max Output Resolution
3840 x 2160 - 60 Hz
Length
20.5 cm
Space grey
Connectors
24 pin USB-C - male (input)
Connectors (Second End)
HDMI - female (output) , DisplayPort - female (output)
Displayport 1.2/Thunderbolt 3
4K support, active adapter
3-year warranty
Cable Type
Adapter 4K support, active
Interface Supported
DisplayPort / HDMI
Jacket Material
Aluminium
Length
20.5 cm
HDR support, HBR2 audio support, multi-channel audio, DisplayPort Alternate Mode support, Parade PS8338 chipset, ITE Tech IT6563 chipset
Space grey
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Connectors
19 pin HDMI Type A - female (output) , 20 pin DisplayPort - female (output)
FCC, RoHS, WEEE, REACH, RCM
6.2 cm
1.5 cm
48 g
Shipping Width
17.3 cm
Shipping Depth
8 cm
Shipping Height
2 cm
Shipping Weight
70 g
Limited warranty - 3 years
FVKR StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.03
FVKR StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.55
FVKR StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.54
FVKR StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £13.68
FVKR StarTech.com 2m 6.6ft DisplayPort 1.4 Cable In Stock £14.89
FVKR StarTech.com 3m 9.8ft DisplayPort 1.4 Cable In Stock £29.40
FVKR StarTech.com 5m DisplayPort 1.4 Cable In Stock £35.86
FVKR StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.26
FVKR StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD In Stock £22.45
FVKR StarTech.com USB C Multiport Video Adapter - VGA or DisplayPort - HDR 4K60 - Display Adapter In Stock £16.89
FVKR StarTech.com USB C Multiport Video Adapter - HDMI or Mini DisplayPort -HDR 4K Display Adapter In Stock £32.99
Length: 20.5cm
