Here's an all-in-one USB-C adapter for your MacBook Pro, Dell XPS or other USB-C laptop, with all the ports you need for maximum productivity. The USB-C multiport adapter with HDMI turns your laptop into a portable workstation, adding 4K video, Gigabit Ethernet, and two USB 3.0 ports, plus laptop charging with Power Delivery 3.0.
Use the USB-C adapter as a portable docking station, connecting your laptop to a 4K HDMI monitor (4096 x 2160p) to create a workstation or make presentations. It also connects to an ultrawide monitor.
The USB-C adapter gives you one USB-C port to connect a USB-C device, and one USB-A port to attach a mouse, keyboard or other peripheral. Fast-charge your mobile device using the USB-A port.
With support for 100W Power Delivery 3.0, the USB Type-C multiport adapter provides up to 92W laptop charging, and powers your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you unplug to switch power sources (USB-C power adapter to bus power).
The USB Type-C multiport adapter has a built-in wrap-around cable for easy connection and portability.
The Gigabit Ethernet port ensures reliable wired network access.
Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
Connect a UHD 4K HDMI Monitor
Use the USB-C adapter as a?portable docking station, connecting your laptop to?a?4K?HDMI monitor?(4096 x 2160p)?to create a workstation or make presentations.?It also connects to?an ultrawide monitor. -
Connect?Your?Devices
The?USB-C adapter?gives you one?USB-C port to connect a USB-C device, and one USB-A?port to attach a mouse, keyboard or other peripheral. Fast-charge your mobile device using the USB-A port. -
Laptop Charging with PD 3.0
With support for?100W?Power Delivery?3.0,?the?USB?Type-C multiport adapter?provides up to 92W laptop charging, and powers your peripherals?when connected to a USB-C power adapter.?PD?3.0 features Fast Role Swap to prevent USB data disruption when?you?unplug?to?switch?power sources (USB-C?power adapter to?bus power). -
Wrap-Around Cable
The USB Type-C multiport adapter has a built-in wrap-around cable for easy connection and portability. -
Reliable?Network?Connectivity
The Gigabit Ethernet port ensures reliable wired network access.? DKT30CHCPD is backed by a StarTech.com 3-year warranty and free lifetime technical support.? Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
- StarTech.com USB C Multiport Adapter, USB-C Travel Mini Dock to 4K HDMI with 100W PD 3.0 Pass-Through, USB-A USB-C, Gigabit Ethernet, Portable USB 3.0 Type-C Dock with 100W Power Delivery - Mac, Windows, Chrome (DKT30CHCPD) - docking station - USB-C - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- 6 cm x 9 cm x 1.4 cm
- 75 g
- Black
- Networking
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Docking station
- 6 cm
- 9 cm
- 1.4 cm
- 75 g
- Enclosure Colour
- Black
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
- 1 x USB-C - 24 pin USB-C , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A (power only) , 1 x display / video - HDMI output - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
- Cables Included
- 1 x USB-C cable - external
- USB powered, UASP transfer protocol, 1 USB 3.0 fast charging port, full duplex support, auto MDIX support
- cUL, FCC, WEEE, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0
- OS Required
- Google Chrome OS, Apple MacOS X 10.9 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- Shipping Weight
- 158 g
- 0 °C
- 45 °C
StarTech.com USB-C Multifunction Adapter | In Stock | £47.42 |
StarTech.com USB-C to VGA Adapter with PD | In Stock | £12.06 |
StarTech.com 4m USB 2.0 C Cable w/ PD (5A) | In Stock | £15.43 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £14.59 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £26.27 |
