StarTech.com USB-C Multiport Adapter w/HDMI or VGA w/100W PD
Quicklinx: FRVVWS00 Mfr#: DKT30CHVAUSP
Device Type: Macbook, Chromebook, Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black, Space grey
36 In Stock
£22.27 ex VAT
£26.72 inc VAT
USB-C Mini Dock 100W PD Passthrough USB-C & A Ports SD Card Reader Mac, Windows & ChromeOS Android OS GbE. This USB-C multiport adapter turns your MacBook Pro, USB-C laptop, Chromebook or Android (Samsung Galaxy S8, Note 9 and above) device into a workstation, anywhere you go. A USB Type-C adapter, ideal for travel, features everything from the essential HDMI or VGA video outputs and USB ports to an SD card reader and 100W PD including PD passthrough. All through a single extended length 30 cm Thunderbolt 3 or USB-C attached host cable, providing more flexibility for harder to reach laptop and tablet connections.
Two Video Output Options with HDMI or VGA
This USB-C multiport adapter features both an HDMI and VGA port providing you with two single video output options for your boardroom presentations or your workstation setup including support for an ultra-wide monitor.
Power & Charge with 100W Power Delivery 3.0
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. The USB-C hub features PD passthrough so you can use your laptop's own charger to power the hub (requires 15W) and power or charge your laptop simultaneously.
All the Essential Ports with USB
The USB-C to USB 3.0 hub gives you one USB-C port (power & data) and two USB-A ports to connect your latest and legacy USB devices.
Includes Ports to Do More with SD, Audio & Gigabit Ethernet
Access your multimedia content, audio, and network with ease. The multiport adapter provides direct access to your:
SD, SDHC and SDXC memory cards or microSD cards via the SD card slot
Audio content via headphones or microphone through the 3.5mm 4- position audio port
Ethernet network via the GbE port using a hard-wired connection
DKT30CHVAUSP is backed by a StarTech.com 3-year warranty and free lifetime technical support.
  • Two Video Output Options with HDMI or VGA
  • Power & Charge with 100W Power Delivery 3.0
  • All the Essential Ports with USB
  • Includes Ports to Do More with SD, Audio & Gigabit Ethernet
    Access your multimedia content, audio, and network with ease. The multiport adapter provides direct access to your: • SD, SDHC and SDXC memory cards or microSD cards via the SD card slot • Audio content via headphones or microphone through the 3.5mm 4- position audio port • Ethernet network via the GbE port using a hard-wired connection
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB C Multiport Adapter, USB-C Mini Travel Dock with 4K HDMI or 1080p VGA, 3x USB 3.0 Hub, SD, GbE, Audio, 100W PD Pass-Through, Portable Docking Station for Laptop/Tablet - USB 3.0 Mini Dock - docking station - USB-C - VGA, HDMI - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
VGA, HDMI
6 cm x 11.6 cm x 1.5 cm
114 g
Black, space grey
Gigabit Ethernet
3-year warranty
Docking station
6 cm
11.6 cm
1.5 cm
114 g
Enclosure Colour
Black, space grey
Video
Max Resolution Details
4096 x 2160 - 24 Hz , 3840 x 2160 - 30 Hz , 3440 x 1440 - 60 Hz
2 x USB 3.1 Gen 1 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x video - VGA - 15 pin D-Sub (DB-15) , 1 x headphone/microphone combo jack - mini-phone 3.5 mm 4-pole , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C
Input Device
SD card reader
1 x USB-C cable - integrated - 30 cm
4K Ultra HD, 100W power delivery
FCC, RoHS, REACH, USB Power Delivery 3.0
Android, Google Chrome OS, Apple iOS, Apple OS X 10.11 El Capitan, Apple macOS Sierra 10.12, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS Ventura 13.0
Limited warranty - 3 years
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
45 °C
Device Type: Chromebook
Device Type: Laptop
Colour: Black
Colour: Space grey
