StarTech.com USB C Multiport Adapter PD, 4K
Quicklinx: GKNBWS00 Mfr#: CDP2HDUACP2
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Grey
13 In Stock
£22.72 ex VAT
£27.26 inc VAT
This USB-C multiport adapter with HDMI lets you add vital connections to your laptop with a single USB-C port. The USB C mini docking station features automatic driver installation and supports Windows, macOS, Chrome OS, Linux and Android, providing a portable connectivity solution for your USB-C laptop, tablet, phone, Ultrabook or Chromebook. The multiport adapter is also compatible with Thunderbolt 3, and Thunderbolt 4 laptops like MacBook Pro/Air, HP EliteBook, Dell XPS/Latitude, Lenovo Thinkpad X1 & Surface Laptop 3/Book 3.
  • 3-in-1 Multiport Adapter with 4K 30Hz HDMI Video Output
    The USB-C mini docking station features an HDMI output that supports video resolutions up to 4K 30Hz, providing a high-resolution screen to maximize your productivity when multi-tasking using an HDMI desktop monitor (3440x1440 ultra-wide monitors/displays supported). You can also connect to an HDMI projector or TV in a boardroom or other meeting space, to deliver presentations on a shared screen. Other output ports included on the adapter are a USB-A port (USB 3.2 Gen 1 5Gbps & BC 1.2 charging) for connecting and charging devices, and a USB-C (5Gbps Data + 100W Power Delivery 3.0) for charging your laptop or connecting to a downstream USB-C peripheral device.
  • Portable, Travel Friendly Design with Extra Long Cable
    The USB-C adapter has a 13 in. (34 cm) attached cable that provides extended reach that reduces port/connector strains when connected to 2-in-1 devices like Surface Pro (7+), and on laptops that are resting on riser stands. The adapter also features a compact, portable design that fits easily into your laptop bag, making it ideal for on-the-go use as travel accessory with your laptop and other portable devices.
  • Bus-Powered or 100W USB Power Delivery 3.0
    To provide power flexibility in different applications, the USB-C multiport adapter can operate using bus power alone, or it can be connected to an external USB-C power adapter up to 100W. The adapter features 100W Power Delivery 3.0 pass through, enabling you to charge your laptop and connected devices. When connected to a power adapter up to 92W of power are available for charging, while 8W of power are reserved for the USB-C multiport adapter, this power reserve avoids video flickering and device dropouts, caused by overdrawing power, common in other hubs, ensuring this adapter provides high-performance operation, while reliably charging your devices. When a power adapter isn't connected, this adapter operates using USB bus power, and the USB-C port where you connect your power adapter turns into a downstream 5Gbps USB Type-C port for connecting USB-C peripheral devices. Note: The adapter will not be as effective at charging downstream devices, when a USB-C power adapter is not connected.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | USB Event Monitoring Utility : To track and log connected USB devices For more information and to download the StarTech.com Connectivity Tools application, please visit: StarTech.com/Connectivity-Tools CDP2HDUACP2 is backed by a 3-year StarTech.com warranty, and free lifetime multilingual, North American based technical support.
StarTech.com USB C Multiport Adapter, USB-C to HDMI 4K Video, 100W Power Delivery Passthrough Charging, 2-Port USB 3.0 Hub 5Gbps (1xType-C/1xA), USB-C Mini Dock, USB-C Travel Dock - Portable Laptop Docking Station - docking station - USB-C / Thunderbolt 3 / Thunderbolt 4 - HDMI
Docking station
Docking Interface
Video Interfaces
HDMI
11.5 cm x 6 cm x 1 cm
102 g
Grey
3-year warranty
Docking station
11.5 cm
6 cm
1 cm
102 g
Enclosure Colour
Grey
Video
Max Resolution Details
4096 x 2160 - 24 Hz , 3840 x 2160 - 30 Hz , 3440 x 1440 - 60 Hz , 1920 x 1080 - 120 Hz
USB 3.2 Gen 1, USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 1
1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 1 with Power Delivery 3.0 (100 W) - 24 pin USB-C
1 x USB-C cable - integrated - 34 cm
100W power delivery, DisplayPort Alt Mode
USB Power Delivery 3.0, RoHS
Limited warranty - 3 years
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
102 g
45 °C
GKNB StarTech.com 1m USB to Lightning Cable In Stock £13.44
GKNB StarTech.com 1m USB to Lightning Cable - Black In Stock £13.53
GKNB StarTech.com 2m USB to Lightning Cable In Stock £16.63
GKNB StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £10.00
GKNB StarTech.com 2 m / 6.6 ft USB 2.0 to USB C Cable – Black In Stock £12.01
GKNB StarTech.com 1 m / 3.3 ft USB C Cable – Black In Stock £9.84
GKNB StarTech.com 2 m / 6.6 ft USB C Cable – Black In Stock £11.99
Device Type: Laptop
Colour: Grey
