StarTech.com USB-C Multiport Adapter HDMI
Quicklinx: GKNFWS00 Mfr#: DKT30CHPD3
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Grey
10 In Stock
£51.79 ex VAT
£62.14 inc VAT
USB-C Multiport Adapter - 4k 60Hz HDMI 2.0b - 100W Power Delivery Passthrough - 4-Port USB Hub.
  • Enhance Productivity
    The portable docking station connects your laptop to a 4K 60Hz HDMI monitor (4096 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
  • Connect Your Devices
    The USB-C to USB 3.1 Gen 1 hub gives you three USB-A ports to connect your legacy USB devices, plus one shared USB-C port for either power delivery pass through.
  • Charge Your Laptop and Peripherals
    With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power). The DKT30CHPD3 is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note:?To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
StarTech.com USB C Multiport Adapter, USB-C to HDMI 2.0b 4K 60Hz (HDR10), 100W Power Delivery Pass-Through, 4-Port 5Gbps USB 3.0 Hub, USB Type-C Mini Dock, with 12" (30cm) Attached Cable - Thunderbolt 3 Compatible (DKT30CHPD3) - docking station - USB-C - HDMI
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI
4.5 cm x 3 cm x 1.3 cm
93 g
Black & grey
3-year warranty
Docking station
4.5 cm
3 cm
1.3 cm
93 g
Enclosure Colour
Black & grey
Video
Max Resolution Details
4K - 60 Hz (DisplayPort 1.4 over USB-C) , 4K - 30 Hz (DisplayPort 1.2 over USB-C)
1 x display / video - HDMI - 19 pin HDMI Type A , 3 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C
1 x USB-C cable - integrated - 30 cm
4K Ultra HD, bus powered, Parade PS176 chipset, VLI VL102 chipset, VLI VL817 chipset
FCC, RoHS, WEEE, RCM
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple MacOS X 10.9 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Google Chrome OS
Additional Requirements
Must support DisplayPort over USB-C or DP Alt Mode
Limited warranty - 3 years
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
126 g
45 °C
GKNF StarTech.com 4m USB 2.0 C Cable w/ PD (5A) In Stock £15.43
GKNF StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.59
GKNF StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £26.27
GKNF StarTech.com Multiport Adapter HDMI/VGA In Stock £21.73
Device Type: Laptop
Colour: Grey
