This USB-C multiport adapter with HDMI turns your MacBook Pro, Dell XPS, or other USB-C laptop into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI video output, a USB Type-C port (data/power), two USB 3.0 Type-A ports, a Gigabit Ethernet port and an SD card reader slot, all through one connection to your laptop's USB-C or Thunderbolt 3 port. Plus, it offers advanced charging through USB Power Delivery 3.0.
The portable docking station connects your laptop to a 4K HDMI monitor (4096 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
The USB-C to USB 3.0 hub gives you one USB-C port and two USB-A ports to connect your latest and legacy USB devices.
Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD cards (with adapter, sold separately).
With support for USB PD 3.0 (up to 60W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
The Gigabit Ethernet port ensures reliable wired network access.
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
Enhance Productivity
The portable docking station connects your laptop to a 4K HDMI monitor (4096 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor. -
Connect Your Devices
The USB-C to USB 3.0 hub gives you one USB-C port and two USB-A ports to connect your latest and legacy USB devices. -
Built-In SD Card Reader
Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD cards (with adapter, sold separately). -
Charge Your Laptop and Peripherals
With support for USB PD 3.0 (up to 60W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power). -
Reliable Network Connectivity
The Gigabit Ethernet port ensures reliable wired network access. The DKT30CSDHPD3 is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note:?To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
- StarTech.com USB C Multiport Adapter - USB-C Travel Dock to 4K HDMI, 3x USB 3.0 Hub, SD/SDHC, GbE, 60W PD 3.0 Pass-Through - USB Type-C/Thunderbolt 3 - Upgraded Version of DKT30CSDHPD (DKT30CSDHPD3) - docking station - USB-C - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- 4.5 cm x 27 cm x 1.5 cm
- 85 g
- Space grey
- Networking
- Gigabit Ethernet
- 3-year warranty
- Designed For
- P/N: ARMPIVOTE2, FPPNEUSTND, MONSTADQI
- Product Type
- Docking station
- 4.5 cm
- 27 cm
- 1.5 cm
- 85 g
- Enclosure Colour
- Space grey
- Data Link Protocol
- Gigabit Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
- 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB-C - 24 pin USB-C (power only) , Video - HDMI input - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
- Compatible Slots
- SDXC Memory Card
- Cables Included
- 1 x USB-C cable - 27 cm
- USB powered, 4K Ultra HD, auto MDIX support, 60W power delivery
- FCC, RoHS, WEEE, UASP (USB Attached SCSI Protocol)
- OS Required
- Android, Google Chrome OS, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- Shipping Weight
- 100 g
- 0 °C
- 45 °C
- Designed For
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.54 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £9.71 |
StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops | In Stock | £6.77 |
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 | In Stock | £55.27 |
StarTech.com USB-C Multifunction Adapter | In Stock | £45.80 |
StarTech.com USB-C to 4K HDMI Adapter with Power Delivery | In Stock | £44.93 |
StarTech.com USB-C to VGA Adapter with PD | In Stock | £11.93 |
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £68.98 |
StarTech.com USB C Multiport Adapter PD, 4K | In Stock | £19.96 |
StarTech.com 3-Port USB-C Hub w/Gb Ethernet | In Stock | £27.82 |
StarTech.com 4-Port USB-C Hub, 5Gbps, PD | In Stock | £39.46 |
