StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0
Quicklinx: DXFRWS00 Mfr#: DKT30CSDHPD3
Device Type: Laptop, Macbook
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Space grey
More than 50 In Stock
£59.47 ex VAT
£71.36 inc VAT
This USB-C multiport adapter with HDMI turns your MacBook Pro, Dell XPS, or other USB-C laptop into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI video output, a USB Type-C port (data/power), two USB 3.0 Type-A ports, a Gigabit Ethernet port and an SD card reader slot, all through one connection to your laptop's USB-C or Thunderbolt 3 port. Plus, it offers advanced charging through USB Power Delivery 3.0.
The portable docking station connects your laptop to a 4K HDMI monitor (4096 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
The USB-C to USB 3.0 hub gives you one USB-C port and two USB-A ports to connect your latest and legacy USB devices.
Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD cards (with adapter, sold separately).
With support for USB PD 3.0 (up to 60W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
The Gigabit Ethernet port ensures reliable wired network access.
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
  • Enhance Productivity
  • Connect Your Devices
  • Built-In SD Card Reader
  • Charge Your Laptop and Peripherals
  • Reliable Network Connectivity
    The Gigabit Ethernet port ensures reliable wired network access. The DKT30CSDHPD3 is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note:?To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
StarTech.com USB C Multiport Adapter - USB-C Travel Dock to 4K HDMI, 3x USB 3.0 Hub, SD/SDHC, GbE, 60W PD 3.0 Pass-Through - USB Type-C/Thunderbolt 3 - Upgraded Version of DKT30CSDHPD (DKT30CSDHPD3) - docking station - USB-C - 1GbE
Docking station
Docking Interface
USB-C
4.5 cm x 27 cm x 1.5 cm
85 g
Space grey
Gigabit Ethernet
3-year warranty
P/N: ARMPIVOTE2, FPPNEUSTND, MONSTADQI
Docking station
4.5 cm
27 cm
1.5 cm
85 g
Enclosure Colour
Space grey
Gigabit Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB-C - 24 pin USB-C (power only) , Video - HDMI input - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
Compatible Slots
SDXC Memory Card
1 x USB-C cable - 27 cm
USB powered, 4K Ultra HD, auto MDIX support, 60W power delivery
FCC, RoHS, WEEE, UASP (USB Attached SCSI Protocol)
Android, Google Chrome OS, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Weight
100 g
45 °C
DXFR StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.54
DXFR StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
DXFR StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £55.27
DXFR StarTech.com USB-C Multifunction Adapter In Stock £45.80
DXFR StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £44.93
DXFR StarTech.com USB-C to VGA Adapter with PD In Stock £11.93
DXFR StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £68.98
DXFR StarTech.com USB C Multiport Adapter PD, 4K In Stock £19.96
DXFR StarTech.com 4-Port USB-C Hub, 5Gbps, PD In Stock £38.84
Device Type: Laptop
Device Type: Macbook
Colour: Space grey
