Expand the connectivity of your Thunderbolt 3/USB-C port enabled laptop. Compatible with Mac and Windows, this universal USB-C multiport adapter lets you turn your laptop into a powerful workstation, anywhere you go. The USB-C adapter provides a 4K Ultra HD HDMI video output, an ultra high-speed SD 4.0 card reader (with UHS-II support), a USB 3.0 Type-A port and one Gigabit Ethernet port, through your laptop's USB-C port. Plus, the adapter supports USB Power Delivery 2.0, so you can power the adapter and your laptop at the same time using a USB Type-C power adapter.
Connect a 4K Ultra HD monitor
The USB-C multiport adapter offers a 4K Ultra HD HDMI port (with audio), so you can easily connect a high-resolution monitor (4096 x 2160p @ 24Hz or 3840 x 2160p @ 30Hz). -
Fast SD card access
The USB-C multiport adapter features a memory card slot, providing fast read and write access for SD and microSD (with adapter) memory cards through USB 3.0. The card reader offers SD 4.0 and UHS-II support, allowing high-speed file transfers at up to 312MB/s. It's ideal for transferring photos or videos from your SD cards to your USB-C enabled laptop or tablet. -
The ports you need most
The Gigabit Ethernet port on the multiport adapter ensures reliable wired network access. Plus, an additional USB 3.0 port (USB Type-A) lets you connect a peripheral device like your mouse or flash drive. The DKT3CHSD4GPD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
- StarTech.com USB C Multiport Adapter - 4K HDMI - SD / SDHC / SDXC - Power Delivery (USB PD) - USB-C to USB Adapter - USB Type C Adapter (DKT3CHSD4GPD) - docking station - USB-C - HDMI - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- HDMI
- 11 cm x 5 cm x 1.8 cm
- 100 g
- White, silver
- Networking
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Docking station
- 11 cm
- 5 cm
- 1.8 cm
- 100 g
- Enclosure Colour
- White, silver
- Data Link Protocol
- Gigabit Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 1 x USB-C - 24 pin USB-C , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB-C (power port) - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
- Compatible Slots
- SD / MMC Memory Card
- Cables Included
- 1 x USB-C cable - external - 15 cm
- Wake on LAN, USB powered, UASP transfer protocol, full duplex support, 4K Ultra HD, 60W charging
- FCC, RoHS, WEEE
- OS Required
- Google Chrome OS, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- Shipping Weight
- 250 g
- 5 °C
- 35 °C
