This USB-C multiport adapter with HDMI turns your Macbook Pro, Macbook Air (including M1s), Google Pixelbook and other USB-C tablets and laptops into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K 30Hz HDMI video output, a USB Type-C port (data/power), one USB 3.2 Gen 1 Type-A (5Gbps) ports, an SD and MicroSD (uSD) card reader, all through a single connection to your laptop's USB-C or Thunderbolt 3 port. It offers advanced charging through USB 100W Power Delivery 3.0 and eliminates the need for an attached cable with a retractable USB-C connection that connects directly to your USB-C host without the need for an attached cable.
Enhance Productivity
The portable docking station supports a single HDMI monitor up to 4K 30Hz (3840 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor. -
Connect Your Devices
The USB-C to USB 3.2 Gen 1 hub gives you one USB-C port and one USB-A port (BC 1.2 charging port) to connect your latest and legacy USB devices. -
Built-In SD Card Reader
Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD cards. -
Charge Your Laptop and Peripherals
With support for USB Power Delivery 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. The multiport adapter itself reserves 8W leaving up to 92W of power for charging. The DKT30CMHSDPD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note:?To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
- StarTech.com USB C Multiport Adapter for MacBook Pro/Air, USB Type-C to 4K HDMI, 100W Power Delivery Pass-through Charging, SD/MicroSD Slot, 2-Port USB 3.0 Hub, Portable USB-C Mini Dock - Works w/ Thunderbolt 3 - docking station - USB-C / Thunderbolt 3 - HDMI
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- HDMI
- 11.3 cm x 10.5 cm x 3.5 cm
- 78 g
- Power
- Power Provided
- 3-year warranty
- Product Type
- Docking station
- 11.3 cm
- 10.5 cm
- 3.5 cm
- 78 g
Video
- Max Resolution Details
- 3840 x 2160 - 30 Hz
- USB 3.2 Gen 1
- Expansion Slots
- 1 (total) / 1 (free) x SD / MMC Memory Card , 1 (total) / 1 (free) x microSD
- 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 1 with Power Delivery 3.0 (100 W) - 24 pin USB-C
- Input Device
- SD card reader, microSD card reader
- Retractable connector, 100W power delivery
- FCC, RoHS, USB Power Delivery 3.0
- OS Required
- Android, Google Chrome OS, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple iPadOS, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Windows 8 / 10 / 11, Apple macOS Ventura 13.0
- Limited warranty - 3 years
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 145 g
- 0 °C
- 70 °C
StarTech.com USB C Dock DP 4K30Hz or VGA | In Stock | £102.44 |
