StarTech.com USB C Multiport Adapter
Quicklinx: GKNGWS00 Mfr#: DKT30CMHSDPD
Device Type: Other, Laptop, Macbook, Tablet
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Grey
32 In Stock
£22.64 ex VAT
£27.16 inc VAT
This USB-C multiport adapter with HDMI turns your Macbook Pro, Macbook Air (including M1s), Google Pixelbook and other USB-C tablets and laptops into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K 30Hz HDMI video output, a USB Type-C port (data/power), one USB 3.2 Gen 1 Type-A (5Gbps) ports, an SD and MicroSD (uSD) card reader, all through a single connection to your laptop's USB-C or Thunderbolt 3 port. It offers advanced charging through USB 100W Power Delivery 3.0 and eliminates the need for an attached cable with a retractable USB-C connection that connects directly to your USB-C host without the need for an attached cable.
  • Enhance Productivity
    The portable docking station supports a single HDMI monitor up to 4K 30Hz (3840 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
  • Connect Your Devices
    The USB-C to USB 3.2 Gen 1 hub gives you one USB-C port and one USB-A port (BC 1.2 charging port) to connect your latest and legacy USB devices.
  • Built-In SD Card Reader
    Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD cards.
  • Charge Your Laptop and Peripherals
    With support for USB Power Delivery 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. The multiport adapter itself reserves 8W leaving up to 92W of power for charging. The DKT30CMHSDPD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note:?To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
StarTech.com USB C Multiport Adapter for MacBook Pro/Air, USB Type-C to 4K HDMI, 100W Power Delivery Pass-through Charging, SD/MicroSD Slot, 2-Port USB 3.0 Hub, Portable USB-C Mini Dock - Works w/ Thunderbolt 3 - docking station - USB-C / Thunderbolt 3 - HDMI
Docking station
Docking Interface
Video Interfaces
HDMI
11.3 cm x 10.5 cm x 3.5 cm
78 g
3-year warranty
Docking station
11.3 cm
10.5 cm
3.5 cm
78 g
Video
Max Resolution Details
3840 x 2160 - 30 Hz
USB 3.2 Gen 1
Expansion Slots
1 (total) / 1 (free) x SD / MMC Memory Card , 1 (total) / 1 (free) x microSD
1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 1 with Power Delivery 3.0 (100 W) - 24 pin USB-C
Input Device
SD card reader, microSD card reader
100W power delivery, retractable connector
USB Power Delivery 3.0, FCC, RoHS
Windows 8 / 10 / 11, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Google Chrome OS, Apple iPadOS, Android
Limited warranty - 3 years
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
145 g
70 °C
GKNG StarTech.com USB C Dock DP 4K30Hz or VGA In Stock £89.78
Device Type: Other
Device Type: Laptop
Device Type: Macbook
Device Type: Tablet
Colour: Grey
