StarTech.com USB-C Multiport Adapter
Quicklinx: GXJNWS00 Mfr#: DKM31C3HVCPD
12 In Stock
£70.66 ex VAT
£84.79 inc VAT
7-IN-1 MULTIPORT ADAPTER: Single or Multi Monitor DP 1.4 Alt Mode, HDMI 2.0b, VGA, USB-C port with DP Alt Mode for video or 10Gbps Data, plus 2 x USB-A 3.2 Gen 2 10Gbps hub, 100W USB PD Pass-Through (88W laptop charging), Gigabit Ethernet.
USB-C DOWNSTREAM PORT WITH VIDEO OUTPUT: Industry's first non-Thunderbolt adapter features a 10Gbps USB-C port w/ DP Alt Mode; Connect a portable USB-C monitor or desktop monitor w/USB-C Display Adapter as an extended display, or USB-C peripheral.
FLEXIBLE VIDEO:1x 4K 60Hz HDMI or USB-C DP Alt Mode video, or 2x 4K 30Hz HDMI + USB-C (discrete DP 1.4 GPU) - 1x 4K 30Hz HDMI or USB-C, or 4K 30Hz + 1080p 60Hz in dual monitor (integrated DP 1.4 GPU) - 1x 4K 30Hz HDMI or USB-C, or 2x 1080p (DP 1.2 GPU).
EXTRA LONG CABLE: 10" (25cm) cable for extended reach reducing port/connector strain on 2-in-1 devices like Surface Pro 7/8, iPad Pro, HP Elite X2 or laptops on riser stands; Hideaway cable design stores attached cable during travel.
COMPATIBILITY: Mini dock compatible w/USB-C laptops/Ultrabooks/Chromebooks/Surface/Thunderbolt 3/4/USB4 laptops from HP/Dell/Lenovo; Windows/Android/Linux/ChromeOS - For optimal video performance use with Intel 11th & 12th gen+ laptop CPUs.
CONNECTIVITY TOOLS: Provided with the mobile all-in-one USB Type C docking station adapter this application improves performance and security; Featuring MAC Address Changer, USB Event Monitoring, Windows Layout, and Wi-Fi Auto Switch utilities.
  • Versatile, High-Performance Video via MST
    The compact USB Type-C Docking Station features three video output options to turn your laptop into a single or multi-monitor workstation. HDMI Port Provides HDR video with resolutions up to 4K 60Hz. VGA Port Provides analog video with resolutions up to 1080p 60Hz. USB-C Port Provides the industry's first downstream full featured video or data (10Gbps) USB-C port that supports DP Alt Mode video or peripheral connection, on a non-Thunderbolt adapter. The advanced video versatility of this Multiport Adapter, makes it suitable for a wide variety of applications: • Connect a portable USB-C monitor as an extended display, to obtain a high resolution external monitor during on-the-go travel between an office desk, home office, hot desk, or the boardroom. • Connect a USB-C peripheral to the downstream 10Gbps USB-C port, while using the HDMI and/or VGA ports to connect external monitor(s) as extended display(s). • Connect multiple external monitors as extended displays, using any combination of the two video ports, to create a high-productivity workstation. USB-C video adapters (sold separately) can be used to connect HDMI, DVI, VGA, or DisplayPort monitors to the USB-C video port. This Docking Station utilizes MST to obtain video versatility. Video performance is based upon the number of attached monitors and the host computer's video controller. Consult the manufacturer of the host computer to determine MST video performance. StarTech.com performs rigorous performance benchmarks with all major host computer video controllers. The video performance results of our testing are listed below: Notes: • This chart displays maximum performance capabilities. Performance varies depending on system configuration. Check with your host computer manufacturer to determine expected video performance. • A laptop with a discrete GPU is recommended for maximum performance.
  • Connect Your Devices
    The USB 3.2 Gen 2 (10Gbps) hub features two USB-A ports and one USB-C port, for connecting your USB devices. The downstream USB-C port can be used to connect a monitor, or USB-C peripheral with up to 10W (5V/2A) of power, to power or charge your peripherals.
  • Multiple Use Cases
    A versatile docking solution for use at an office desk, home office, hot desk, or in the boardroom. It's portable enough to be carried in a bag / backpack for mobile use. The USB-C dock can operate with bus-power alone, or with a USB-C power adapter connected to the USB Power Delivery pass-through port - for full laptop and USB-C peripheral charging. The lightweight docking station features a built-in 10 in (25 cm) USB-C host cable for added setup flexibility and to reduce port strain with laptop connection elevated off desktop surface.
  • Charge Your Laptop and Peripherals
    With support for USB PD 3.0 (100W - 88W charging, 12W reserved for multiport adapter), the Multiport Adapter enables charging of the host computer and peripherals connected to the USB-C port. USB PD is only available when a USB-C power adapter is connected to the PD pass-through port. PD 3.0 features Fast Role Swap (FRS) which prevents USB data disruption when switching power sources (e.g., USB-C power adapter to bus power).
  • Reliable Network Connectivity
    The Gigabit Ethernet port ensures reliable wired network access. Support for Wake-on-LAN (WoL) enables remote booting of the host computer.
StarTech.com USB-C Multiport Adapter with USB-C DP Alt Mode Video Output / 4K HDMI 2.0 / VGA, USB-C Dual Monitor Docking Station, 100W PD Pass-Through, USB Type C Mini Dock/MST Adapter Hub - 2x USB-A 10Gbps, GbE (DKM31C3HVCPD) - docking station - USB-C 3.2 Gen 2 / Thunderbolt 3 / Thunderbolt 4 - HDMI, USB-C, VGA - 1GbE - TAA Compliant
Docking station
Docking Interface
Video Interfaces
HDMI, USB-C, VGA
8.3 cm x 14.4 cm x 2.8 cm
168 g
Space grey
Gigabit Ethernet
TAA Compliant
3-year warranty
Docking station
8.3 cm
14.4 cm
2.8 cm
168 g
Enclosure Colour
Space grey
Video
Max Resolution Details
3840 x 2160 - 60 Hz (HDMI only) , 3840 x 2160 - 60 Hz (DisplayPort 1.4 over USB-C) , 3840 x 2160 - 30 Hz (HDMI and DisplayPort 1.4 over USB-C simultaneously) , 1920 x 1200 - 60 Hz (VGA only)
USB 3.2 Gen 2
1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x USB-C 3.2 Gen 2/DisplayPort - 24 pin USB-C , 2 x USB 3.2 Gen 2 - 9 pin USB Type A , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C (power only) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x USB-C 3.2 Gen 2 cable - integrated - 25 cm
HDR10 support, full duplex support, 100W power delivery (pass-through), USB-C Alt Mode, MST (multi-stream transport), wake on LAN, plastic housing
DisplayPort 1.4, USB Power Delivery 3.0, UASP (USB Attached SCSI Protocol), FCC, RoHS, WEEE
TAA Compliant
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Google Chrome OS, Android, Linux
Limited warranty - 3 years
Shipping Width
14.4 cm
Shipping Depth
20.7 cm
Shipping Height
3.8 cm
Shipping Weight
258 g
60 °C
GXJN StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.98
GXJN StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.72
GXJN StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
GXJN StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.83
GXJN StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £15.43
