StarTech.com USB C Multiport Adapter 4K
Quicklinx: GMBKWS00 Mfr#: DKT31CSDHPD3
Device Type: Macbook, Tablet, Other, Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Space grey
10 In Stock
£45.46 ex VAT
£54.55 inc VAT
This USB-C multiport adapter with DP 1.4 supports 4K 60Hz HDMI (HDR) and turns your MacBook Pro, Dell XPS, or other USB-C laptops or tablet into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI video output, two USB 3.1 Gen 2 Type-A (10Gbps) ports, an SD card reader and a Gigabit Ethernet port all through one connection to your laptop's USB-C or Thunderbolt 3/4 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 10-inch (25 cm) host cable for an extended reach to offer more set up flexibility. USB 3.1 Gen 2 (10Gbps) is also known as USB 3.1 Gen 2x1 (10Gbps).
  • Enhance Productivity
    The portable docking station connects your laptop to a 4K 60Hz HDMI monitor (4096 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
  • Connect Your Devices
    The USB-C to USB 3.1 Gen 2 hub gives you two USB-A (10Gbps) ports to connect your USB devices.
  • Easy Portability
    For mobile use, the USB-C adapter can operate with bus-power alone, or with a USB-C power adapter for laptop and BC 1.2 peripheral charging. The docking station is lightweight and features a built-in wraparound USB-C host cable.
  • Built-In SD Card Reader
    Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD (uSD) cards.
  • Charge Your Laptop and Peripherals
    With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
StarTech.com USB C Multiport Adapter, USB C to 4K 60Hz HDMI 2.0, 2-Port 10Gbps USB Hub, 100W Power Delivery Pass-through, GbE, SD/MicroSD, USB Type-C Mini Dock, 10"/25cm Attached Cable - USB C Docking Station - docking station - USB-C - HDMI
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI
14.2 cm x 8.2 cm x 2.9 cm
150 g
Space grey
3-year warranty
Docking station
14.2 cm
8.2 cm
2.9 cm
150 g
Enclosure Colour
Space grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Expansion Slots
1 (total) / 1 (free) x SD / MMC Memory Card
2 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x USB 3.1 Gen 2 with Fast Charging - 24 pin USB-C , 1 x USB-C with Power Delivery (100 W) (power only) - 24 pin USB-C , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
Input Device
SD card reader
1 x USB-C cable - integrated - 25 cm
Preboot Execution Environment (PXE) support, full duplex support, plastic housing, HDR10 support, Parade PS186 chipset, DisplayPort Alt Mode
IEEE 802.3, USB Power Delivery 3.0, DisplayPort 1.2, DisplayPort 1.4, RoHS, FCC, WEEE, RCM
Windows 8 / 10 / 11, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Google Chrome OS, Apple iPadOS, Android 9.0 (Pie), Android 10, Android 11
Limited warranty - 3 years
Shipping Width
21 cm
Shipping Depth
14.4 cm
Shipping Height
4 cm
Shipping Weight
270 g
50 °C
GMBK StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.34
GMBK StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.86
GMBK StarTech.com 3ft Premium Certified HDMI 2.0 In Stock £10.78
GMBK StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.98
GMBK StarTech.com USB C Multiport Adapter, 4K In Stock £31.89
GMBK StarTech.com USB-C Multiport Adapter 4K60Hz In Stock £38.35
GMBK StarTech.com 4-Port USB-C Hub, 5Gbps, PD In Stock £39.46
Device Type: Tablet
Device Type: Other
Device Type: Laptop
Colour: Space grey
