StarTech.com USB C Multiport Adapter 4K
Quicklinx: GJJLWS00 Mfr#: DKT30CHSDPD1
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black, Space grey
More than 50 In Stock
£30.95 ex VAT
£37.14 inc VAT
This USB-C multiport adapter with HDMI turns your MacBook Pro, Dell XPS, or other USB-C laptops into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI video output, two USB 3.2 Gen 2 Type-A (10Gbps) ports, and a USB Type-C port (power/data), all through one connection to your laptop's USB-C or Thunderbolt 3 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 12-inch (30 cm) host cable for an extended reach to offer more set up flexibility.
The portable docking station connects your laptop to a 4K 30Hz HDMI monitor (3840 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
The USB-C to USB 3.2 Gen 1 hub gives you two USB-A ports one and a USB-C port (shared power/data) to connect your latest and legacy USB devices.
Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD (uSD) cards.
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
  • Enhance Productivity
    The portable docking station connects your laptop to a 4K 60Hz HDMI monitor (4096 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
  • Connect Your Devices
    The USB-C to USB 3.2 Gen 1 hub gives you two USB-A ports to connect your legacy USB devices.
  • Built-In SD Card Reader
  • Charge Your Laptop and Peripherals
  • Reliable Network Connectivity
    The Gigabit Ethernet port ensures reliable wired network access.
StarTech.com USB C Multiport Adapter, USB-C to 4K 60Hz HDMI 2.0, 100W Power Delivery Pass-through, SD/MicroSD, 2-Port USB 3.0 Hub, GbE, USB Type-C Mini Dock, 12" (30cm) Long Attached Cable - Works w/Thunderbolt 3 (DKT30CHSDPD1) - docking station - USB-C / Thunderbolt 3 - HDMI - 1GbE
Docking station
Docking Interface
Video Interfaces
HDMI
35.2 cm x 3.4 cm x 1.4 cm
99 g
Black, space grey
Gigabit Ethernet
3-year warranty
Docking station
35.2 cm
3.4 cm
1.4 cm
99 g
Enclosure Colour
Black, space grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz
USB 3.0
Expansion Slots
1 (total) / 1 (free) x SD / MMC Memory Card , 1 (total) / 1 (free) x microSD
1 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB 3.2 Gen 1 with Fast Charging - 9 pin USB Type A , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C with Power Delivery (100 W) (power only) - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
Input Device
SD card reader, microSD card reader
1 x USB-C cable - integrated - 30 cm
100W power delivery, HDR support, DisplayPort Alt Mode
DisplayPort 1.4, USB Power Delivery 3.0, FCC, RoHS
Windows 8 / 10 / 11, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Google Chrome OS, Apple iPadOS, Android
Limited warranty - 3 years
Shipping Width
10 cm
Shipping Depth
18 cm
Shipping Height
2 cm
Shipping Weight
180 g
70 °C
GJJL StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
GJJL StarTech.com USB C Multiport Adapter, 4K In Stock £31.89
GJJL StarTech.com USB C Multiport Adapter 4K In Stock £45.46
GJJL StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £43.64
GJJL StarTech.com USB C Multiport Adapter 2 HDMI In Stock £63.61
GJJL StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £29.52
GJJL StarTech.com USB-C Multiport Adapter In Stock £67.04
GJJL StarTech.com USB C Multiport Adapter In Stock £81.16
GJJL StarTech.com USB-C Multiport Adapter, HDMI In Stock £31.51
GJJL StarTech.com USB-C Multiport Adapter, HDMI In Stock £27.89
GJJL StarTech.com USB-C Triple Monitor Docking Station In Stock £142.84
GJJL StarTech.com USB-C Multiport Adapter - HDMI/VGA In Stock £26.89
GJJL StarTech.com USB-C Speakerphone Dock In Stock £77.32
GJJL StarTech.com USB-C Triple-Monitor Adapter In Stock £85.93
GJJL StarTech.com USB-C/USB-A Multiport Adapter In Stock £51.84
GJJL StarTech.com USB-C Triple-Monitor Adapter In Stock £85.35
Device Type: Laptop
Colour: Black
Colour: Space grey
