This USB-C multiport adapter turns your Windows laptop into a portable workstation. The USB-C to dual Display Port adapter connects your USB-C laptop to two DisplayPort monitors, letting you power through work faster or make presentations with different views on two displays. It gives you two USB-A ports, a Gigabit Ethernet port, a DP Alt Mode Switch, and laptop charging.
Through 100W?Power Delivery?3.0,?the?USB Type-C to DisplayPort adapter powers itself as well as your laptop and any attached peripherals, with up to 85W laptop charging when connected to a USB-C power adapter.?PD?3.0 features Fast Role Swap to prevent USB data disruption when?you?unplug?the power adapter to?switch?power sources (USB-C?power adapter to?bus power).
The USB-C video adapter extends your laptop screen to?dual DisplayPort displays. Using the DP Alt Mode switch, you can choose between higher display resolution or faster USB speed to meet your needs, for desktop or portable use. Choose between: dual 4K30 (or single 4K60) resolution with USB 2.0 speed, or dual 1080p (or single 4K30) resolution with USB 3.0 speed.
DisplayPort Alternate Mode to Choose Your Video Display Output
Achieve dual 1080p up to a single 4K 60Hz display using the DisplayPort Alternate Mode (DP Alt-Mode) configuration switch. -
Reliable 100W Power Delivery Passthrough
The USB-C multiport adapter uses your USB-C laptop's power adapter and can provide up to 100W Power Delivery (3.0) pass through with up to 85W for your host device for charging. The remaining wattage will power the docking station along with any attached USB-A peripherals such as smartphones and tablets. -
Multi-Stream Transport for Driverless Displays
The multi-stream transport technology (MST) in this dock powers two DisplayPort monitors with no driver installation required so you are up and running faster. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN. -
Comprehensive Product Testing & Expert Technical Support
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to our customers. Our local StarTech.com Technical Advisors have a broad product expertise and work directly with StarTech.com Engineers to provide support for our customers both pre and post-sales. This docking station is backed by a StarTech.com 3-Year warranty and free lifetime technical support.
- StarTech.com USB C Dock, 4K Dual Monitor DisplayPort, Mini Laptop Docking Station, 100W Power Delivery Passthrough, GbE, 2-Port USB-A Hub, USB Type-C Multiport Adapter 3.3' Cable, Dual DP - Portable USB-C Dock (DK30C2DAGPD) - docking station - USB-C - 2 x DP - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- 2 x DP
- 6 cm x 12 cm x 1.18 cm
- 200 g
- Black
- Networking
- Gigabit Ethernet
- 3-year warranty
- Designed For
- P/N: ARMBARDUO, ARMBARDUOV, ARMDUAL, ARMDUAL30, ARMDUALV, ARMSLIMDUO
- Product Type
- Docking station
- 6 cm
- 12 cm
- 1.18 cm
- 200 g
- Enclosure Colour
- Black
Video
- Max Resolution Details
- 4096 x 2160 - 60 Hz
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 1 x USB 3.1 Gen 1 - 24 pin USB-C , 1 x USB 3.1 Gen 1 with Power Delivery - 24 pin USB-C , 2 x display / video - 20 pin DisplayPort , 1 x network - 1000Base-T - RJ-45 , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x USB-C cable - external - 1 m
- Dual monitor support, DisplayPort Alt Mode, 100W power delivery
- FCC, RoHS, UASP (USB Attached SCSI Protocol)
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Limited warranty - 3 years
- Shipping Weight
- 220 g
- 0 °C
- 50 °C
- Designed For
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £15.96 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £15.89 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £19.60 |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £139.14 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £150.32 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £217.58 |
StarTech.com Dual Monitor Stand | In Stock | £76.36 |
StarTech.com DisplayPort to HDMI - 4K 60Hz | In Stock | £19.93 |
StarTech.com Vertical Dual Monitor Stand | In Stock | £74.76 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £24.06 |
StarTech.com Thin Client Mount - VESA | In Stock | £21.09 |
StarTech.com 1.8m USB 3.1 5Gbps with PD (5A) C to C Cable - M/M Certified | In Stock | £25.00 |
StarTech.com 20" USB C Cable 10Gbps Gen2 | In Stock | £13.14 |
StarTech.com USB C Dock DP 4K30Hz or VGA | In Stock | £76.62 |
