StarTech.com USB C Multiport Adapter 2 HDMI
Quicklinx: GTBBWS00 Mfr#: 120B-USBC-MULTIPORT
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Space grey
More than 50 In Stock
£63.61 ex VAT
£76.33 inc VAT
This USB Type-C Multiport Adapter with DP 1.4 Alternative Mode, DSC and MST, supports dual-HDMI (HDR) video with resolutions of up to 4K 60Hz uncompressed video. The mini travel dock turns your Dell XPS, Lenovo X1 Carbon, HP Elite/ProBook, or other USB-C laptop into a workstation, anywhere you go. The USB-C docking station provides dual HDMI outputs, a 2-port USB 3.2 Gen 1 Type-A (5Gbps) Hub including a BC 1.2 port to power and charge a USB peripheral, SD and MicroSD card readers, and a Gigabit Ethernet port, all through one connection to your laptop's USB-C or Thunderbolt 3/4 port. In addition, it offers advanced charging through USB Power Delivery (PD) 3.0 pass-through via an integrated 12-inch (30 cm) USB-C host cable, for more set up flexibility.
  • High-Performance Dual-HDMI Video via MST
    The compact docking station connects your laptop to two HDMI monitors, creating a powerful workstation. It supports DP 1.4 Alt Mode with DSC and MST, for uncompressed video performance up to dual 4K (3840 x 2160p) at 60Hz, depending upon your host computer. The dock also supports the use of ultrawide monitors. Video performance, such as resolution and refresh rate across both monitors, is dependent upon your host computer and its video controller. A source device with support for DisplayPort 1.4, paired with DSC and DP 1.4 enabled HDMI displays, are required to achieve dual 4K 60Hz. Please review the specifications of your computer and displays, to determine expected video performance. StarTech.com performs rigorous performance benchmarks with all major computer models. The video performance results of our testing are listed below:
  • Connect Your Devices
    The USB-C to USB 3.2 Gen 1 (5Gbps) hub provides two USB-A ports for connecting your USB devices.
  • Multiple Use Cases
    A versatile dock solution for use at your office desk, home office, hotel desk, or in the boardroom. It's portable enough to be carried in your bag / backpack for mobile use. The USB-C dock can operate with bus-power alone, , or with a USB-C power adapter connected to the pass-through port - for full laptop and peripheral charging. The lightweight docking station features a built-in 12 in (30 cm) USB-C host cable.
  • Built-In SD Card Reader
    Access your multimedia content with ease. The multiport adapter provides direct access to your SD / SDHC / SDXC or microSD (uSD) memory cards.
  • Charge Your Laptop and Peripherals
    With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter enables you to power and charge your laptop and a USB peripheral, when a USB-C power adapter is connected to the pass-through port. PD 3.0 features Fast Role Swap (FRS) which prevents USB data disruption when switching power sources (e.g., USB-C power adapter to bus power).
StarTech.com USB C Multiport Adapter, Dual HDMI Video, 4K 60Hz, 2-Port 5Gbps USB-A Hub, 100W Power Delivery Charging, GbE, SD/MicroSD, USB Type-C Mini Travel Dock, 12"/30cm Cable - USB C Laptop Docking Station - docking station - USB-C / Thunderbolt 3 / Thunderbolt 4 - 2 x HDMI - 1GbE
Docking station
Docking Interface
Video Interfaces
2 x HDMI
14.5 cm x 5.9 cm x 1.4 cm
165 g
Space grey
Gigabit Ethernet
3-year warranty
Docking station
14.5 cm
5.9 cm
1.4 cm
165 g
Enclosure Colour
Space grey
Video
Max Resolution Details
3840 x 2160 - 60 Hz (Dual Display)
USB 3.1, USB 3.2 Gen 1
Expansion Slots
1 (total) / 1 (free) x SD Memory Card , 1 (total) / 1 (free) x microSD
2 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C with Power Delivery (100 W) (power only) - 24 pin USB-C
Input Device
microSD card reader, SD card reader
1 x USB-C cable - integrated - 30 cm
100W power delivery (pass-through), dual display support, DisplayPort Alt Mode, Fast Role Swap, MST (multi-stream transport), HDR10 support, LED indicator, full duplex support, wake on LAN
USB Power Delivery 3.0, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.4, DSC, UASP (USB Attached SCSI Protocol), RoHS, WEEE
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Google Chrome OS
Limited warranty - 3 years
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
165 g
45 °C
GTBB StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.91
GTBB StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.54
GTBB StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
GTBB StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
GTBB StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.85
GTBB StarTech.com USB-C Multiport Adapter Docking Station In Stock £118.27
GTBB StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.97
GTBB StarTech.com USB-C Multiport Adapter 4K60Hz In Stock £19.44
GTBB StarTech.com 3-Port USB-C Hub w/Gb Ethernet In Stock £28.25
GTBB StarTech.com USB-C Triple-Monitor Adapter In Stock £85.93
GTBB StarTech.com USB-C Triple-Monitor Adapter In Stock £85.35
Device Type: Laptop
Colour: Space grey
