This USB Type-C Multiport Adapter with DP 1.4 Alternative Mode, DSC and MST, supports dual-HDMI (HDR) video with resolutions of up to 4K 60Hz uncompressed video. The mini travel dock turns your Dell XPS, Lenovo X1 Carbon, HP Elite/ProBook, or other USB-C laptop into a workstation, anywhere you go. The USB-C docking station provides dual HDMI outputs, a 2-port USB 3.2 Gen 1 Type-A (5Gbps) Hub including a BC 1.2 port to power and charge a USB peripheral, SD and MicroSD card readers, and a Gigabit Ethernet port, all through one connection to your laptop's USB-C or Thunderbolt 3/4 port. In addition, it offers advanced charging through USB Power Delivery (PD) 3.0 pass-through via an integrated 12-inch (30 cm) USB-C host cable, for more set up flexibility.
High-Performance Dual-HDMI Video via MST
The compact docking station connects your laptop to two HDMI monitors, creating a powerful workstation. It supports DP 1.4 Alt Mode with DSC and MST, for uncompressed video performance up to dual 4K (3840 x 2160p) at 60Hz, depending upon your host computer. The dock also supports the use of ultrawide monitors. Video performance, such as resolution and refresh rate across both monitors, is dependent upon your host computer and its video controller. A source device with support for DisplayPort 1.4, paired with DSC and DP 1.4 enabled HDMI displays, are required to achieve dual 4K 60Hz. Please review the specifications of your computer and displays, to determine expected video performance. StarTech.com performs rigorous performance benchmarks with all major computer models. The video performance results of our testing are listed below: -
Connect Your Devices
The USB-C to USB 3.2 Gen 1 (5Gbps) hub provides two USB-A ports for connecting your USB devices. -
Multiple Use Cases
A versatile dock solution for use at your office desk, home office, hotel desk, or in the boardroom. It's portable enough to be carried in your bag / backpack for mobile use. The USB-C dock can operate with bus-power alone, , or with a USB-C power adapter connected to the pass-through port - for full laptop and peripheral charging. The lightweight docking station features a built-in 12 in (30 cm) USB-C host cable. -
Built-In SD Card Reader
Access your multimedia content with ease. The multiport adapter provides direct access to your SD / SDHC / SDXC or microSD (uSD) memory cards. -
Charge Your Laptop and Peripherals
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter enables you to power and charge your laptop and a USB peripheral, when a USB-C power adapter is connected to the pass-through port. PD 3.0 features Fast Role Swap (FRS) which prevents USB data disruption when switching power sources (e.g., USB-C power adapter to bus power).
- StarTech.com USB C Multiport Adapter, Dual HDMI Video, 4K 60Hz, 2-Port 5Gbps USB-A Hub, 100W Power Delivery Charging, GbE, SD/MicroSD, USB Type-C Mini Travel Dock, 12"/30cm Cable - USB C Laptop Docking Station - docking station - USB-C / Thunderbolt 3 / Thunderbolt 4 - 2 x HDMI - 1GbE
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- 2 x HDMI
- 14.5 cm x 5.9 cm x 1.4 cm
- 165 g
- Space grey
- Networking
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Docking station
- 14.5 cm
- 5.9 cm
- 1.4 cm
- 165 g
- Enclosure Colour
- Space grey
Video
- Max Resolution Details
- 3840 x 2160 - 60 Hz (Dual Display)
- Data Link Protocol
- USB 3.1, USB 3.2 Gen 1
- Expansion Slots
- 1 (total) / 1 (free) x SD Memory Card , 1 (total) / 1 (free) x microSD
- 2 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C with Power Delivery (100 W) (power only) - 24 pin USB-C
- Input Device
- microSD card reader, SD card reader
- Cables Included
- 1 x USB-C cable - integrated - 30 cm
- 100W power delivery (pass-through), dual display support, DisplayPort Alt Mode, Fast Role Swap, MST (multi-stream transport), HDR10 support, LED indicator, full duplex support, wake on LAN
- USB Power Delivery 3.0, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.4, DSC, UASP (USB Attached SCSI Protocol), RoHS, WEEE
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Google Chrome OS
- Limited warranty - 3 years
- Shipping Width
- 17 cm
- Shipping Depth
- 14.2 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 165 g
- 0 °C
- 45 °C
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.62 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.98 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £9.72 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.83 |
StarTech.com USB-C Multiport Adapter Docking Station | In Stock | £128.94 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £15.43 |
StarTech.com USB-C Multiport Adapter 4K60Hz | In Stock | £38.62 |
StarTech.com 3-Port USB-C Hub w/Gb Ethernet | In Stock | £36.70 |
StarTech.com USB-C Triple-Monitor Adapter | In Stock | £93.20 |
StarTech.com USB-C Triple-Monitor Adapter | In Stock | £106.60 |
