StarTech.com USB C Multiport Adapter
Quicklinx: H13HWS00 Mfr#: 102B-USBC-MULTIPORT
Device Type: Macbook, Tablet, Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Space grey
£81.16 ex VAT
£97.39 inc VAT
This USB-C Mini Dock / Multiport Adapter supports up to dual 4K 60Hz HDMI 2.0 converting your Dell XPS, MacBook or other USB-C laptop or tablet into a workstation, anywhere you go. The USB Type-C Multiport Adapter features 2x HDMI video outputs, a 2-Port USB 3.2 Gen 2 (10 Gbps) Hub (1x USB-A with B.C 1.2 charging, and 1x USB-C), an SD card reader, and Gigabit Ethernet. The adapter connects to your host computer's USB-C, USB4, or Thunderbolt 3/4 port. Charge your host laptop and any attached USB peripherals by connecting the host laptop's power supply to the dedicated USB Power Delivery (PD) 3.0 port. The Multiport Adapter features an extra-long attached 12-inch (30 cm) host cable - for an extended reach, to offer more set up flexibility.
  • DisplayLink Certified Dual 4K 60Hz HDMI Video
    The Mini Docking Station is DisplayLink Certified and supports high-performance dual-monitor 4K 60Hz video resolution with an integrated DisplayLink DL-6950 Controller. Multi-monitor performance makes this dock ideal for high-resolution applications such as video editing and graphic design. The Multiport Adapter supports ultrawide 21:9 aspect ratios, and lower resolutions like 1920x1200/1080p.
  • Connect Your Devices
    The USB-C to USB 3.2 Gen 2 hub features two downstream 10 Gbps USB ports, including 1x USB-C data port for connecting your USB-C peripherals, and 1x USB-A data + 7.5W BC 1.2 charging port for connecting and charging USB-A peripherals.
  • Multiple Use Cases
    A versatile dock solution for use at your office, home office, hotel, or in the boardroom, and is portable enough to be carried in your bag or backpack for mobile use. This lightweight USB-C Adapter can operate with bus-power alone, or use the dedicated USB-C Power Delivery port to connect a USB-C power adapter (not included with Multiport Adapter) for laptop charging.
  • Built-In SD Card Readers
    Access your multimedia content with ease. The Multiport Adapter provides direct access to your SD, SDHC and SDXC memory cards.
  • Charge Your Laptop
    With support for USB Power Delivery 3.0 pass through (up to 100W), the USB Type-C Multiport Adapter allows you to power and charge your laptop, when connected to a USB-C power source. PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power). This allows you to charge the connected host device, as well as any devices connected to the USB-A BC 1.2 charging port.
StarTech.com Universal USB C multiport adapter - Apple M1/M2 Dual Display compatible - DisplayLink Cert Dual 4K 60Hz HDMI 2.0b - 1xA/1xC USB 3.2 10Gbps hub | 100W PD charging - Type-C Mini docking station - Power adapter/bus powered - Win/Chrome/macOS - docking station - USB-C / USB4 / Thunderbolt 3 / Thunderbolt 4 - 2 x HDMI - 1GbE
Docking station
Docking Interface
Video Interfaces
2 x HDMI
9.5 cm x 9.5 cm x 1.7 cm
250 g
Space grey
Gigabit Ethernet
3-year warranty
Docking station
9.5 cm
9.5 cm
1.7 cm
250 g
Enclosure Colour
Space grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz (Dual Display)
USB 3.2 Gen 2, Power Delivery 3.0, Battery Charging 1.2, USB4
Expansion Slots
1 (total) / 1 (free) x SD / MMC Memory Card
2 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB 3.2 Gen 2 with Battery Charging 1.2 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C with Power Delivery (100 W) (power only) - 24 pin USB-C
Input Device
SD card reader
1 x USB-C cable - integrated - 30 cm
Up to 10Gbps data transfer, Preboot Execution Environment (PXE) support, full duplex support, 100W power delivery (pass-through), 20W power consumption, plastic housing, USB-C powered, HDR10 support, DisplayLink DL-6950 chipset, Fast Role Swap, wake on LAN
UASP (USB Attached SCSI Protocol), RoHS, RCM, WEEE, Thunderbolt 3, Thunderbolt 4, DisplayLink certified
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Google Chrome OS, Android, Ubuntu Linux 18.04, Ubuntu Linux 20.04, Apple macOS 10.11 - 10.12, Apple macOS 10.14 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Width
14.5 cm
Shipping Depth
14.5 cm
Shipping Height
4.2 cm
Shipping Weight
400 g
35 °C
H13H StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
H13H StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.54
H13H StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
H13H StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.34
H13H StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.86
H13H StarTech.com USB-C Multiport Adapter Docking Station In Stock £118.27
H13H StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.98
H13H StarTech.com USB-C Multiport Adapter, HDMI In Stock £31.51
H13H StarTech.com USB-C Multiport Adapter, HDMI In Stock £27.89
H13H StarTech.com USB-C/USB-A Multiport Adapter In Stock £51.56
Device Type: Tablet
Device Type: Laptop
Colour: Space grey
