StarTech.com USB-C Multiport Adapter, HDMI
Quicklinx: H1SZWS00 Mfr#: 103B-USBC-MULTIPORT
Device Type: Chromebook, Macbook, Tablet, Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Space grey
£35.73 ex VAT
£42.87 inc VAT
This Works With Chromebook (WWCB) certified USB-C Multiport Adapter supports up to 4K 60Hz HDMI 2.0b (HDR10) via DP Alt Mode. The USB-C dock converts a USB-C laptop or tablet, such as a Chromebook, Dell XPS, or a MacBook, into a workstation. The adapter connects to a host computer's USB-C, USB4, or Thunderbolt 3/4 port. It features one HDMI video output, a 2-Port USB 3.2 Gen 1 (5 Gbps) Hub, and Gigabit Ethernet. Connect a laptop USB-C power supply to the dedicated USB Power Delivery (PD) 3.0 port, located on the Multiport Adapter, to charge the laptop. The Multiport Adapter features an extra-long built-in 12-inch (30 cm) USB-C host cable.
  • Works With Chromebook (WWCB) certified
    This USB-C Multiport Adapter is tested and certified to meet Google's compatibility standards ensuring seamless operation with Chromebook devices. The Multiport Adapter is ideal for setup and deployment in Google environments. Automatic firmware updates are available through ChromeOS for maximum security, compatibility, and performance.
  • Connect USB Peripherals
    The USB-C to USB 3.2 Gen 1 hub features two 5Gbps USB Type-A ports, for connecting USB peripherals.
  • Multiple Use Cases
    A versatile dock solution for use at your office, home office, hotel, or in the boardroom. It's portable enough to be carried in a bag or backpack. This lightweight USB-C Adapter can operate with bus-power alone, or use the dedicated USB-C Power Delivery port to connect a USB-C power adapter (not included with Multiport Adapter) for laptop charging.
  • Charge Your Laptop
    Connect a USB-C power source (not included), such as the power adapter included with a laptop, to the USB-C Power Delivery pass-through port. With support for USB Power Delivery 3.0 pass-through (up to 100W), the USB Type-C Multiport Adapter allows you to power and charge your laptop. USB PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when disconnecting the power source.
  • Wired Gigabit Network Connectivity
    The Gigabit Ethernet port ensures reliable wired network access, with support for PXE Boot and Wake-on-LAN (WoL).
StarTech.com USB-C Multiport Adapter, 4K 60Hz HDMI w/HDR, 2-Port 5Gbps USB 3.0 Hub, 100W Power Delivery Pass-Through, GbE, USB Type C Mini Docking Station, Works with Chromebook certified - Windows, macOS (103B-USBC-MULTIPORT) - docking station - USB-C / USB4 / Thunderbolt 3 / Thunderbolt 4 - HDMI - 1GbE
Docking station
Docking Interface
Video Interfaces
HDMI
10 cm x 4.8 cm x 1.6 cm
105 g
Space grey
Gigabit Ethernet
3-year warranty
Docking station
10 cm
4.8 cm
1.6 cm
105 g
Enclosure Colour
Space grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz
USB 3.2 Gen 1
1 x display / video - HDMI - 19 pin HDMI Type A , 2 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB-C with Power Delivery (86 W) - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x USB-C 3.2 Gen 1 cable - integrated - 30 cm
Wake on LAN, firmware upgradable, Preboot Execution Environment (PXE) support, full duplex support, DisplayPort Alt Mode, HDR support, USB-C powered, plastic housing, HDR10 support, 100W power delivery (pass-through), 5Gbps data transfer, Fast Role Swap (FRS)
RoHS, DisplayPort 1.4, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0, Works With Chromebook (WWCB) certified
Android, Google Chrome OS, Apple macOS Catalina 10.15, Ubuntu Linux 18.04, Apple macOS Big Sur 11.0, Ubuntu Linux 20.04, Apple macOS Monterey 12.0, Microsoft Windows 10 / 11, Apple macOS 13.0
Limited warranty - 3 years , Technical support - assistance - lifetime
Shipping Width
11.5 cm
Shipping Depth
18 cm
Shipping Height
4 cm
Shipping Weight
120 g
35 °C
H1SZ StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £9.78
H1SZ StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £10.14
H1SZ StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.03
H1SZ StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.55
H1SZ StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £16.15
H1SZ StarTech.com 10ft Premium Certified HDMI In Stock £19.46
H1SZ StarTech.com USB-C Multiport Adapter, HDMI In Stock £30.40
Device Type: Macbook
Device Type: Tablet
Device Type: Laptop
Colour: Space grey
