StarTech.com USB C Multiport Adapter, 4K
Quicklinx: GLR9WS00 Mfr#: DKT31CHPD3
Device Type: Laptop, Other, Macbook, Tablet
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Space grey
£31.89 ex VAT
£38.26 inc VAT
This USB-C multiport adapter with support for 4K 60Hz HDMI (HDR) turns your MacBook Pro, Dell XPS, or other USB-C laptops or tablet into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI video output, a USB 3.1 Gen 2 Type-A (10Gbps) port (supporting BC 1.2/7.5W device charging), a USB 3.1 Gen 2 Type-C (10Gbps) port, and an additional USB 3.1 Gen 2 Type-C port that can also be used as a 100W PD 3.0 pass through port - all through one connection to your laptop's USB-C or Thunderbolt 3/4 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 10-inch (25 cm) host cable for an extended reach to offer more set up flexibility. USB 3.1 Gen 2 (10Gbps) is also known as USB 3.2 Gen 2x1 (10Gbps).
  • Enhance Productivity
    The portable docking station connects your laptop to a 4K 60Hz HDMI monitor (4096 x 2160p) to create a powerful workstation. It can also connect to an ultra-wide monitor with resolutions up to 3440x1440 60Hz.
  • Connect Your Devices
    The USB-C to USB 3.1 Gen 2 hub gives you a USB-A (10Gbps) port, and a USB-C (10Gbps) port to connect your USB devices. Plus, when using the multifunction adapter without a power adapter connected, the additional USB-C port, that the power adapter connects to, can be used as a USB-C (10Gbps) peripheral port.
  • Easy Portability
    For mobile use, the USB-C adapter can operate with bus-power alone, or with a USB-C power adapter for laptop and BC 1.2 peripheral charging. The docking station is lightweight and fits easily into a laptop bag for on-the-go travel use in your office, home office and shared work spaces.
  • Charge Your Laptop and Peripherals
    With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data and video disruption when you switch power sources (USB-C power adapter to bus power).
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts.
StarTech.com USB C Multiport Adapter, USB-C to 4K 60Hz HDMI 2.0, 100W Power Delivery Pass-through (PD 3.0), 3-Port 10Gbps USB Hub, USB Type-C Mini Dock, 10" (25cm) Cable - Portable Docking Station for Laptops - docking station - USB-C - HDMI - TAA Compliant
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI
8.8 cm x 4.6 cm x 1.5 cm
50 g
Space grey
TAA Compliant
3-year warranty
Docking station
8.8 cm
4.6 cm
1.5 cm
50 g
Enclosure Colour
Space grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz , 3440 x 1440 - 60 Hz , 4096 x 2160 - 30 Hz , 3440 x 1440 - 30 Hz
USB 3.1 Gen 2
1 x USB 3.1 Gen 2 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB-C 3.1 Gen 2 - 24 pin USB-C , 1 x USB-C 3.1 Gen 2 with Power Delivery (100 W) - 24 pin USB-C , 1 x display / video - HDMI - 19 pin HDMI Type A
1 x USB-C cable - integrated - 25 cm
100W power delivery, HDR10 support, DisplayPort Alt Mode, Parade PS186 chipset, plastic housing
USB Power Delivery 3.0, DisplayPort 1.4, DisplayPort 1.2, UASP (USB Attached SCSI Protocol), RoHS, FCC
TAA Compliant
Windows 8 / 10 / 11, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Google Chrome OS, Apple iPadOS, Android, Linux
Limited warranty - 3 years
Shipping Width
21 cm
Shipping Depth
14.4 cm
Shipping Height
4 cm
Shipping Weight
167 g
50 °C
GLR9 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.91
GLR9 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
GLR9 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.85
GLR9 StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.97
GLR9 StarTech.com 20" USB C Cable 10Gbps Gen2 In Stock £13.20
GLR9 StarTech.com USB-C Multiport Adapter 4K60Hz In Stock £19.52
Device Type: Laptop
Device Type: Other
Device Type: Macbook
Device Type: Tablet
Colour: Space grey
