StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock
Quicklinx: GGRLWS00 Mfr#: DKT30ICHPD
Device Type: Other, Laptop, Tablet, Surface Pro
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Silver, Black
Hurry, only 1 left in stock!
£22.75 ex VAT
£27.30 inc VAT
USB-C Multiport Adapter Mac & Windows 4K 60Hz DP1.4 Alt-Mode HDMI 2.0 Thunderbolt 3 Compatible. This USB-C multiport adapter with DP 1.4 compatibility turns your iPad Pro, Surface Pro 7, Google Pixelbook and other USB-C tablets and laptops into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K 60Hz HDMI (HDR10) video output, a USB Type-C port (data/power), two USB 3.2 Gen 1 Type-A (5Gbps) ports, and a TRRS 4-channel audio port for headset and mic, all through a single connection to your laptop's USB-C or Thunderbolt 3 port.
It offers advanced charging through USB 100W Power Delivery 3.0 and eliminates the need for an attached cable with a direct/flush USB-C connection
Enhance Productivity
The portable docking station features DP 1.4 support from the host side and supports a single HDMI monitor resolution up to 4K 60Hz (4096 x 2160p), when connected to devices that support DP 1.4, to create a powerful workstation.
DP Alt Mode Required
Maximum Resolution
DP 1.2 Alternate Mode
Up to 4K 30Hz
DP 1.4 Alternate Mode
Up to 4K 60Hz
Connect Your Devices
The USB-C to USB 3.2 Gen 1 hub gives you two USB-A ports (one BC 1.2 charging port) and a USB-C port (shared for power or data) to connect your USB devices.
Charge Your Laptop and Peripherals
With support for USB Power Delivery 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. The multiport adapter itself reserves 8W leaving up to 92W of power for charging. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
The DKT30ICHPD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
  • Enhance Productivity
  • Connect Your Devices
  • Charge Your Laptop and Peripherals
    With support for USB Power Delivery 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. The multiport adapter itself reserves 8W leaving up to 92W of power for charging. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power). The DKT30ICHPD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note:?To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
StarTech.com USB C Multiport Adapter, USB-C Mini Dock, USB-C to 4K 60Hz HDMI 2.0, With 100W Power Delivery Pass-Through Charging, 3-Port USB 3.0 Hub, Audio, USB Type-C Multiport Adapter - USB-C Travel Dock - docking station - USB-C - HDMI
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI
9 cm x 3.2 cm x 0.85 cm
83 g
Grey
3-year warranty
Docking station
9 cm
3.2 cm
0.85 cm
83 g
Enclosure Colour
Grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz (DisplayPort 1.4 over USB-C) , 4096 x 2160 - 30 Hz (DisplayPort 1.2 over USB-C)
1 x display / video - HDMI - 19 pin HDMI Type A , 2 x SuperSpeed USB 3.0 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C , 1 x headphone/microphone combo jack - mini-phone 3.5 mm 4-pole
4K Ultra HD, bus powered, VLI VL102 chipset, VLI VL817 chipset, Parade PS186 chipset
FCC, RoHS, WEEE, RCM
Windows 8 / 8.1 / 10 / 11, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Google Chrome OS, Apple iPadOS, Android
Additional Requirements
Must support DisplayPort over USB-C or DP Alt Mode
Limited warranty - 3 years
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
110 g
45 °C
GGRL StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
Device Type: Other
Device Type: Laptop
Device Type: Tablet
Device Type: Surface Pro
Colour: Silver
Colour: Black
