StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0
Quicklinx: D0JRWS00 Mfr#: DKT30CSDHPD
More than 50 in stock
£61.41 ex VAT
£73.69 inc VAT
Add more connectivity to your MacBook or other USB-C laptop, with 4K video, Gigabit Ethernet, two USB 3.0 ports and an SD card reader, plus power and charge as you work. Expand the connectivity of your USB-C enabled laptop. This USB-C multiport adapter lets you turn your laptop into a powerful workstation, virtually anywhere you go, and eliminates the hassle of carrying and connecting many different port adapters. The USB-C adapter lets you add 4K Ultra HD HDMI video output, two USB 3.0 Type-A ports, one Gigabit Ethernet port and one SD card reader slot through your laptop's USB-C port.
You can also use your laptop's USB-C power adapter to power both the multiport adapter and your laptop simultaneously, with support for USB Power Delivery 2.0. It's the ideal accessory for your MacBook Pro or other USB Type-C equipped laptop, and it's also Thunderbolt 3 port compatible.
When coupled with your laptop display, this versatile USB-C multiport adapter makes it easy to create a dual-monitor workstation when you need it. It offers a 4K HDMI port (with audio), so you can easily connect a high-resolution monitor and gain access to more screen space. With higher resolutions, you can view more windows at once and increase your productivity.
The Gigabit Ethernet port ensures reliable wired network access, which is ideal for areas with limited Wi-Fi access. Plus, with two additional USB 3.0 ports (USB Type-A) you can connect your existing peripheral devices, like your mouse or flash drive.
The USB-C adapter also features an SD card reader slot so you can access all of your multimedia content.
This multiport adapter means you don't have to carry multiple power adapters with you. Ideal for mobile use, it features a USB-C port that supports USB Power Delivery 2.0 (USB PD 2.0), so you can use your laptop's USB-C power adapter to power both your laptop and the multiport adapter.
The versatile multiport adapter is compact and lightweight, so it's easy to tuck into your laptop bag. It consolidates multiple ports into a single adapter, which means you don't need to bring along multiple single-function adapters.
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
StarTech.com USB C Multiport Adapter - Portable USB Type-C Travel Dock - 4K HDMI, 2-pt USB Hub, SD, GbE, 60W PD Pass-Through - Laptop Dock - docking station
Docking station
Docking Interface
USB-C / Thunderbolt 3
4.6 cm x 11.6 cm x 1.6 cm
86 g
Grey, black
Gigabit Ethernet
3-year warranty
P/N: ARMCBCL, ARMPIVOT, ARMPIVOTB, ARMPIVOTE, ARMPIVOTHD, ARMPIVOTV2, ARMPIVSTND, ARMSLIM, ARMUNONB, LTRISERP, MONSTADJD, MONSTADJDL
Docking station
4.6 cm
11.6 cm
1.6 cm
86 g
Enclosure Colour
Grey, black
Gigabit Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
Expansion Slots
1 (total) / 1 (free) x SD / MMC Memory Card
2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB-C - 24 pin USB-C (power only) , Video - HDMI input - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x USB-C cable - 15.2 cm
USB powered, full duplex support
FCC, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol)
Google Chrome OS, Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.11, Apple macOS 10.12
Limited warranty - 3 years
55 °C
D0JR StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI GbE In Stock £48.85
D0JR StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £68.32
D0JR StarTech.com USB-C Multifunction Adapter 4K In Stock £48.40
D0JR StarTech.com USB-C Multifunction Adapter In Stock £49.28
D0JR StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £35.39
D0JR StarTech.com USB-C to VGA Adapter with PD In Stock £31.26
D0JR StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £61.41
Price Range Ex VAT: 50 - 100
