StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0
Quicklinx: D0JRWS00 Mfr#: DKT30CSDHPD
Device Type: Macbook, Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black, Aluminum Space Grey
£69.47 ex VAT
£83.36 inc VAT
Add more connectivity to your MacBook or other USB-C laptop, with 4K video, Gigabit Ethernet, two USB 3.0 ports and an SD card reader, plus power and charge as you work. Expand the connectivity of your USB-C enabled laptop. This USB-C multiport adapter lets you turn your laptop into a powerful workstation, virtually anywhere you go, and eliminates the hassle of carrying and connecting many different port adapters. The USB-C adapter lets you add 4K Ultra HD HDMI video output, two USB 3.0 Type-A ports, one Gigabit Ethernet port and one SD card reader slot through your laptop's USB-C port.
You can also use your laptop's USB-C power adapter to power both the multiport adapter and your laptop simultaneously, with support for USB Power Delivery 2.0. It's the ideal accessory for your MacBook Pro or other USB Type-C equipped laptop, and it's also Thunderbolt 3 port compatible.
When coupled with your laptop display, this versatile USB-C multiport adapter makes it easy to create a dual-monitor workstation when you need it. It offers a 4K HDMI port (with audio), so you can easily connect a high-resolution monitor and gain access to more screen space. With higher resolutions, you can view more windows at once and increase your productivity.
The Gigabit Ethernet port ensures reliable wired network access, which is ideal for areas with limited Wi-Fi access. Plus, with two additional USB 3.0 ports (USB Type-A) you can connect your existing peripheral devices, like your mouse or flash drive.
The USB-C adapter also features an SD card reader slot so you can access all of your multimedia content.
This multiport adapter means you don't have to carry multiple power adapters with you. Ideal for mobile use, it features a USB-C port that supports USB Power Delivery 2.0 (USB PD 2.0), so you can use your laptop's USB-C power adapter to power both your laptop and the multiport adapter.
The versatile multiport adapter is compact and lightweight, so it's easy to tuck into your laptop bag. It consolidates multiple ports into a single adapter, which means you don't need to bring along multiple single-function adapters.
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
  • Create a powerful workstation
    When coupled with your laptop display, this versatile USB-C multiport adapter makes it easy to create a dual-monitor workstation when you need it. It offers a 4K HDMI port (with audio), so you can easily connect a high-resolution monitor and gain access to more screen space. With higher resolutions, you can view more windows at once and increase your productivity. The Gigabit Ethernet port ensures reliable wired network access, which is ideal for areas with limited Wi-Fi access. Plus, with two additional USB 3.0 ports (USB Type-A) you can connect your existing peripheral devices, like your mouse or flash drive. The USB-C adapter also features an SD card reader slot so you can access all of your multimedia content.
  • Designed for easy portability
    This multiport adapter means you don't have to carry multiple power adapters with you. Ideal for mobile use, it features a USB-C port that supports USB Power Delivery 2.0 (USB PD 2.0), so you can use your laptop's USB-C power adapter to power both your laptop and the multiport adapter. The versatile multiport adapter is compact and lightweight, so it's easy to tuck into your laptop bag. It consolidates multiple ports into a single adapter, which means you don't need to bring along multiple single-function adapters. The DKT30CSDHPD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
StarTech.com USB C Multiport Adapter - Portable USB-C Dock to 4K HDMI, 2-pt USB 3.0 Hub, SD/SDHC, GbE, 60W PD Pass-Through - USB Type-C/Thunderbolt 3 - NEW VERSION AVAILABLE DKT30CSDHPD3 (DKT30CSDHPD) - docking station - USB-C / Thunderbolt 3 - 1GbE
Docking station
Docking Interface
4.6 cm x 11.6 cm x 1.6 cm
86 g
Grey, black
Gigabit Ethernet
3-year warranty
P/N: ARMCBCL, ARMPIVOT, ARMPIVOTB, ARMPIVOTE, ARMPIVOTE2, ARMPIVOTHD, ARMPIVOTV2, ARMPIVSTND, ARMSLIM, ARMUNONB, ARMUNONB1, FPPNEUSTND, LTRISERP, MONSTADJD, MONSTADJDL
Docking station
4.6 cm
11.6 cm
1.6 cm
86 g
Enclosure Colour
Grey, black
Gigabit Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
Expansion Slots
1 (total) / 1 (free) x SD / MMC Memory Card
2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB-C - 24 pin USB-C (power only) , Video - HDMI input - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x USB-C cable - 15.2 cm
USB powered, full duplex support
FCC, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol)
Google Chrome OS, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
55 °C
D0JR StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.98
D0JR StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.72
D0JR StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £57.08
D0JR StarTech.com USB-C Multifunction Adapter In Stock £48.02
D0JR StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £46.74
D0JR StarTech.com USB-C to VGA Adapter with PD In Stock £37.34
D0JR StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £20.64
D0JR StarTech.com USB-C Adapter - PD - Silver In Stock £27.52
D0JR StarTech.com USB C Adapter - 4K HDMI, GbE In Stock £26.78
D0JR StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £69.47
D0JR StarTech.com USB-C Multiport Adapter Docking Station In Stock £124.67
D0JR StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0 In Stock £60.40
D0JR StarTech.com USB-C Multiport Adapter with Unfolding Cable - HDMI1.4 - USB In Stock £38.52
D0JR StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock In Stock £23.87
D0JR StarTech.com USB C Multiport Adapter 4K In Stock £32.46
D0JR StarTech.com USBC Multiport Adapter 4K HDMI In Stock £27.44
D0JR StarTech.com USB C Multiport Adapter PD, 4K In Stock £20.92
D0JR StarTech.com USB-C Multiport Adapter HDMI In Stock £53.25
D0JR StarTech.com USB C Multiport Adapter In Stock £23.87
D0JR StarTech.com Multiport Adapter HDMI/VGA In Stock £59.05
D0JR StarTech.com USB C Multiport Adapter, 4K In Stock £33.46
D0JR StarTech.com USB C Multiport Adapter 4K In Stock £47.66
D0JR StarTech.com USB C Mini Dock 4K HDMI In Stock £42.13
D0JR StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £45.76
D0JR StarTech.com USB C Multiport Adapter 2 HDMI In Stock £66.71
D0JR StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £30.95
D0JR StarTech.com USB-C Multiport Adapter In Stock £70.29
D0JR StarTech.com 3-Port USB-C Hub w/Gb Ethernet In Stock £36.13
D0JR StarTech.com USB C Multiport Adapter In Stock £85.11
D0JR StarTech.com 4-Port USB-C Hub, 5Gbps, PD In Stock £40.95
D0JR StarTech.com USB-C Multiport Adapter, HDMI In Stock £33.04
D0JR StarTech.com USB-C Multiport Adapter, HDMI In Stock £29.25
D0JR StarTech.com USB-C Triple Monitor Docking Station In Stock £179.82
D0JR StarTech.com USB-C Multiport Adapter - HDMI/DP In Stock £43.01
D0JR StarTech.com USB-C Multiport Adapter - HDMI/VGA In Stock £28.05
D0JR StarTech.com USB-C Speakerphone Dock In Stock £81.07
D0JR StarTech.com USB-C Triple-Monitor Adapter In Stock £90.11
D0JR StarTech.com USB-C/USB-A Multiport Adapter In Stock £51.56
D0JR StarTech.com USB-C Triple-Monitor Adapter In Stock £94.35
Device Type: Laptop
Colour: Black
Colour: Aluminum Space Grey
