StarTech.com USB-C Multiport Adapter - HDMI/DP
Quicklinx: H5LDWS00 Mfr#: DKT31CDHPD3
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Space grey
Hurry, only 3 left in stock!
£42.02 ex VAT
£50.42 inc VAT
Connect this USB Type-C Multiport Adapter to a USB-C, USB4, or Thunderbolt 3/4 laptop to enable single-display HDMI 2.0b or DisplayPort 1.4 video output via DP Alt Mode, supporting resolutions up to 4K 60Hz. The USB-C dock works with USB Type-C laptops or tablets, such as a Chromebook, Dell XPS, or MacBook. It features a 3-Port USB 3.2 Gen 2 (10Gbps) Hub (2x USB-A, 1x USB-C), and Gigabit Ethernet. Connect the laptop USB-C power supply to the dedicated USB Power Delivery (PD) 3.0 port, to charge the laptop.
  • Extra-Long Cable with Built-in Cable Manager
    The Multiport Adapter features an extra-long attached 12.6in. (32cm) USB-C host cable. The Thermoplastic Elastomer (TPE) cable jacket is softer and more flexible than PVC jacketed cables. The extra-long cable reduces port/connector strain, particularly when laptops are placed on riser stands, or on 2-in-1 devices with raised USB-C ports, such as the Microsoft Surface. In addition, the Multiport Adapter also features an innovative wrap-around cable manager that facilitates tangle-free storage in a laptop bag.
  • USB 3.2 Gen 2 Hub
    Connect one USB-C and two USB-A peripherals to the USB 3.2 Gen 2 (10Gbps) ports. A versatile solution for adding docking station capabilities in an office, home office, hotel, or in the boardroom. It's portable enough to be carried in a bag or backpack. This lightweight USB-C Adapter can operate with bus-power alone or connect a USB-C power adapter (not included with Multiport Adapter) for laptop charging. USB PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when disconnecting the power source.
  • Wired Gigabit Network Connectivity
    The Gigabit Ethernet port ensures reliable wired network access, with support for PXE Boot and Wake-on-LAN (WoL).
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that is compatible with a wide variety of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : Setup and save custom windows layouts. •Text | MAC Address Pass-Through Utility : Improve network security. •Text | USB Event Monitoring Utility : Track and log connected USB devices. •Text | Wi-Fi Auto Switch Utility : Enable quick access to wired LAN.
StarTech.com USB-C Multiport Adapter, 4K 60Hz HDMI/DP Video, 3-Port USB Hub, 100W Power Delivery Pass-Through, GbE, USB Type-C Travel Dock w/ Charging, 1ft/30cm Wrap-Around Cable - Mini Laptop Docking Station (DKT31CDHPD3) - docking station - USB-C - HDMI, DP - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI, DP
6.4 cm x 12.4 cm x 2.5 cm
130 g
Space grey
Gigabit Ethernet
Power adapter 16 Watt Power Provided
3-year warranty
Docking station
6.4 cm
12.4 cm
2.5 cm
130 g
Enclosure Colour
Space grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz
USB 3.2 Gen 2
1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - DisplayPort - 20 pin DisplayPort , 2 x USB-C 3.2 Gen 2 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C (power only) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x USB-C 3.2 Gen 2 cable - integrated - 30 cm
Up to 10Gbps data transfer, Preboot Execution Environment (PXE) support, full duplex support, 100W power delivery (pass-through), plastic housing, 84W charging, 2 LED indicators, wake on LAN, DisplayPort Alt Mode
DisplayPort 1.4, RoHS, WEEE, RCM
Power adapter
Power Provided
16 Watt
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Ubuntu 18.04, Ubuntu 20.04, Google Chrome OS, Apple macOS 10.15, Apple macOS 11, Apple macOS 12, Apple macOS 13.0, Android, Linux
Limited warranty - 3 years
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
154 g
50 °C
H5LD StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.54
H5LD StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
H5LD StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
H5LD StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.85
Device Type: Laptop
Colour: Space grey
