StarTech.com USB-C Multiport Adapter - 10Gbps Mini Dock 4K 60Hz HDMI/DisplayPort/1080p VGA
Quicklinx: G119WS00 Mfr#: DKT31CHDVCM
Device Type: Surface Book, iPad Pro, Tablet, Chromebook + 2 more
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black/Grey
Hurry, only 3 left in stock!
£80.00 ex VAT
£96.00 inc VAT
N/A. This USB-C Gen 2 10Gbps multiport adapter, with backward USB-C laptop compatibility, turns your USB-C or Thunderbolt 3 Windows laptop, MacBook Pro, iPad Pro, Surface, Chromebook, or Android tablet into a workstation, anywhere you go. The USB 3.2 Gen 2 Type-C hub adapter features a unique portable, circular design and all of the essential connections
HDMI, DisplayPort, VGA video options
10Gbps USB-C & USB-A peripheral ports
Attached 24cm (10 in) USB-C host cable
Three Video Output Options
This USB-C multiport adapter features HDMI, DisplayPort, and VGA ports providing you with three single video output options for your workstation setup or boardroom presentations including support for an ultra-wide monitor.
HDMI (Up to 4K 60Hz with DP 1.4 and HDMI 2.0 HDR)
DisplayPort (Up to 4K 60Hz with DP 1.4)
VGA (Up to 1080p)
Designed for Portability & Ease of Use
The USB-C travel dock features a compact circular design and an attached extended length 24cm (10 in.) host cable, accommodating a wide variety of setups. Bus-powered for most applications, there's no need to carry around a separate bulky power adapter. If extra power required, you can use your external USB-C laptop power adapter with support for up to 75W Power Delivery pass-through (15W for docking station & rest for charging).
Installation is fast and simple, with native support in most operating systems, and at only 7 ounces (198 g) and taking up less space than your smartphone, this dock easily fits in your laptop bag or briefcase with a convenient wraparound cable.
Essential Port Configuration
In addition to the video outputs, the portable USB-C dock gives you two 10Gbps USB-A ports and one 10Gbps USB-C port to connect the latest and legacy USB devices. The adapter also integrates a Gigabit Ethernet port to access a wired network.
  • Three Video Output Options
    This?USB-C multiport adapter?features HDMI, DisplayPort, and VGA ports providing you with three ?single?video output options for your?workstation setup or boardroom presentations including support for an ultra-wide monitor. • HDMI ( Up to 4K 60Hz with DP 1.4 and HDMI 2.0 HDR ) • DisplayPort ( Up to 4K 60Hz with DP 1.4 ) • VGA ( Up to 1080p)
  • Designed for Portability & Ease of Use
    The USB-C travel dock features a compact circular design and an attached extended length 24cm (10 in.) host cable, accommodating a wide variety of setups. Bus-powered for most applications, there's no need to carry around a separate bulky power adapter. If extra power required, you can use your external USB-C laptop power adapter with support for up to 75W Power Delivery pass-through (15W for docking station & rest for charging). Installation is fast and simple, with native support in most operating systems, and at only 7 ounces (198 g) and taking up less space than your smartphone, this dock easily fits in your laptop bag or briefcase with a convenient wraparound cable.
  • Essential Port Configuration
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB C Multiport Adapter, USB 3.1 Gen 2 10Gbps Type-C Mini Dock with 4K 60Hz HDMI/DisplayPort or 1080p VGA, 75W PD Passthrough, 3-Port USB Hub, GbE, Mobile Docking Station - 75W Power Delivery - docking station - USB-C 3.1 Gen 2 - VGA, HDMI, DP - 1GbE
Docking station
Docking Interface
USB-C 3.1 Gen 2
Video Interfaces
VGA, HDMI, DP
9 cm x 9 cm x 3.2 cm
201 g
Black & grey
Gigabit Ethernet
3-year warranty
Docking station
9 cm
9 cm
3.2 cm
201 g
Enclosure Colour
Black & grey
1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x network - 1000Base-T - RJ-45 , 1 x USB-C 3.1 Gen 2 - 10 pin USB-C , 1 x display / video - DisplayPort - 20 pin DisplayPort
USB pass-through connector, bus powered, fast charging, HDR support
FCC, RoHS, WEEE, REACH, RCM
Apple macOS Sierra 10.12, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple iPadOS, Apple macOS Big Sur 11.0, Google Chrome OS 69.x, Android 9.x, Apple macOS Monterey 12.0, Windows 8.1 / 10 / 11, Apple macOS Ventura 13.0
Limited warranty - 3 years
Shipping Width
14.1 cm
Shipping Depth
13.2 cm
Shipping Height
3.65 cm
50 °C
G119 StarTech.com USB-C Multiport Adapter - Gen 2 Hub 10Gbps - HDMI and VGA In Stock £55.78
G119 StarTech.com USB C Multiport Adapter - 4K HDMI/PD/USB/GbE- Mini Dock In Stock £56.75
G119 StarTech.com USB C Multiport Adapter In Stock £65.00
Device Type: iPad Pro
Device Type: Tablet
Device Type: Chromebook
Device Type: Laptop
Device Type: Macbook
Colour: Black/Grey
