StarTech.com USB-C Multifunction Adapter
Quicklinx: CFQXWS00 Mfr#: DKT30CHPD
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black
14 In Stock
£45.80 ex VAT
£54.96 inc VAT
Power and charge your laptop through USB Type-C (5Gbps), and create a workstation virtually anywhere you go, adding 4K video, GbE, and two USB 3.0 ports. Here's a vital accessory for your USB-C equipped laptop. This USB-C multifunction adapter lets you create a workstation while you're in the office, or when you travel. And, because it supports USB Power Delivery, you can power and charge your laptop through your USB Type-C port, while simultaneously powering the adapter. It fits nicely in smaller, constrained workspaces, plus you can travel lighter and more conveniently using just a single power adapter instead of multiple.
Now, you can create a permanent or temporary workstation, virtually anywhere. Plus, it's one of the first USB-C adapters to integrate power delivery, making it a must-have accessory if you have a USB-C charged laptop, Chromebook, or MacBook.
This multifunction USB-C adapter converts the video, data, and power input capabilities of your laptop's USB-C port into five individual ports. With additional connectivity, you can save money and use the adapter with your existing peripherals, instead of having to purchase new devices. Plus, it offers a built-in, easy-to-use USB Type-C cable, so you will be able to connect to your laptop without having to carry around a separate host cable.
The next-generation USB-C cable is small and reversible, which makes it easier to insert into your laptop. You can connect the plug with either side facing up, so there's less risk of damaging your laptop port. Plus, because it uses USB-C, the adapter is Thunderbolt 3 data port compatible, so you can connect it to your Thunderbolt 3 equipped laptop.
Now, you can spend more time working, and less time setting up your workstation.
If you're tired of connecting or carrying multiple power adapters with you when you travel, then this multifunction adapter can help. It features a USB-C port that supports USB Power Delivery 2.0 (USB PD 2.0), so you can use your laptop's USB-C power adapter to power both your laptop, and the multifunction adapter.
The versatile multifunction adapter is compact and lightweight, making travel easier and more convenient, so you can set up a workstation virtually anywhere you work or visit. Because it consolidates multiple ports into a single adapter, you eliminate the need to connect or travel with multiple single-function adapters.
The adapter's extended-length cable provides you with more desk placement options, which makes it easier to create a comfortable, space-efficient work area. The 34 cm (13 in.) cable lets you place the adapter exactly where you need it. The cable is long enough to reach your laptop or tablet's USB Type-C port, regardless of where the port is located. Now, you can eliminate the frustration of having a host cable that's too short to reach your laptop's port location.
When coupled with your laptop display, this versatile USB-C multifunction adapter makes it easy to create a dual-monitor workstation when you need it. It offers a 4K HDMI (with audio) port, so you can easily connect a high-resolution monitor and gain access to more screen space. With higher resolutions, you can view more windows at once and increase your overall productivity.
With two additional USB 3.0 ports, as well as Gigabit Ethernet, the adapter gives you the vital connectivity you need when you're in the office or when you travel. And because it features USB-A ports, you can connect your current peripherals and avoid the added cost of purchasing a newer USB-C device.
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP alt mode.
  • Create a Powerful Workstation
    The versatile USB-C adapter lets you create a dual-monitor workstation virtually anywhere, providing 4K Ultra HD (3840 x 2160p) HDMI output with 30 Hz refresh rate and audio, two USB 3.0 ports, and a Gigabit Ethernet port, with support for USB Power Delivery 2.0. The Gigabit Ethernet port with support for Wake-on-LAN (WOL), jumbo frames, VLAN tagging, and Energy-Efficient Ethernet, delivers a reliable wired network connection, ideal for areas with limited Wi-Fi access. Plus, with two additional USB 3.0 ports (USB Type-A) you can connect productivity devices like your mouse and/or flash drive.
  • Designed for Easy Portability
    Ideal for mobile use, the compact multiport adapter supports USB Power Delivery 2.0 (PD 2.0), so you can use your laptop's USB-C power adapter to power both your laptop and the adapter. The adapter also features an integrated extended-length USB-C cable, for added flexibility in connecting to your laptop, which means one less cable to carry with you.
  • The StarTech.com Advantage for Docking Stations
    Maximum compatibility - StarTech.com has a docking station to fit every operating system, laptop brand, and connectivity need Get more done faster - More ports and more displays maximize end-user connectivity and productivity Quick installation - eliminate deployment headaches that waste time and frustrate end users IT Grade quality - trusted by IT pros around the world for our rigorous in-house product testing, robust compliance, and lifetime multilingual technical support The DKT30CHPD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP alt mode.
StarTech.com USB-C Multiport Adapter, USB-C Travel Docking Station with 4K HDMI, 60W Power Delivery Pass-Through, Ethernet (GbE), 2x USB-A 3.0 Hub, Portable Mini USB Type-C Dock for Laptop - Portable USB-C Dock (DKT30CHPD) - adapter - HDMI / USB - TAA Compliant - 9.6 cm
Cable
Adapter - HDMI / USB
TAA Compliant
Max Output Resolution
3840 x 2160 - 30 Hz
Length
9.6 cm
Connectors
24 pin USB-C - male (input)
Connectors (Second End)
HDMI - female (output) , HD-15 (VGA) - female (output) , RJ-45 - female , USB Type A - female
USB / USB 2.0 / USB 3.0 / USB 3.1 Gen 1
4K support, USB Power Delivery (60W)
3-year warranty
P/N: ARMPIVOT, ARMPIVOTE, ARMPIVSTND, ARMSLIM, ARMUNONB
Cable Type
Adapter 4K support, USB Power Delivery (60W)
Interface Supported
HDMI / USB
Jacket Material
Plastic
Length
9.6 cm
DisplayPort Alternate Mode support, Auto MDIX
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Google Chrome OS, Apple MacOS X 10.9 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
Connectors
19 pin HDMI Type A - female (output) , 15 pin HD D-Sub (HD-15) - female (output) , RJ-45 - female , 9 pin USB Type A - female
FCC, RoHS, WEEE, REACH, RCM, USB Power Delivery 2.0, UASP (USB Attached SCSI Protocol), IEEE 802.3
TAA Compliant
5.1 cm
1.8 cm
64 g
Shipping Width
14.6 cm
Shipping Depth
21.2 cm
Shipping Height
4.1 cm
Shipping Weight
198 g
Limited warranty - 3 years
CFQX StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.54
CFQX StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £7.68
CFQX StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
CFQX StarTech.com USB-C Multifunction Adapter In Stock £45.80
CFQX StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £44.93
CFQX StarTech.com USB-C to VGA Adapter with PD In Stock £11.93
CFQX StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £20.26
CFQX StarTech.com 4 Port USB C Hub with PD 2.0 In Stock £34.11
CFQX StarTech.com USB-C Adapter - PD - Silver In Stock £26.25
CFQX StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 In Stock £45.82
CFQX StarTech.com 4m USB 2.0 C Cable w/ PD (5A) In Stock £15.41
CFQX StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £9.00
CFQX StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £25.63
CFQX StarTech.com USB C Adapter - 4K HDMI, GbE In Stock £25.54
CFQX StarTech.com USB-C Multiport Adapter - DVI In Stock £24.59
CFQX StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £68.98
CFQX StarTech.com Dual USB C Dock - Windows - PD In Stock £144.82
CFQX StarTech.com USB-C Multiport Adapter Docking Station In Stock £118.27
CFQX StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0 In Stock £59.47
CFQX StarTech.com USB-C Multiport Adapter with Unfolding Cable - HDMI1.4 - USB In Stock £36.73
CFQX StarTech.com USB-C Adapter with HDMI & VGA In Stock £32.61
CFQX StarTech.com USB-C Multiport Adapter, 4K HDMI or VGA, Type-C Mini Dock In Stock £58.94
CFQX StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock In Stock £22.75
CFQX StarTech.com USB C Multiport Adapter 4K In Stock £30.95
CFQX StarTech.com USBC Multiport Adapter 4K HDMI In Stock £26.15
CFQX StarTech.com USB C Multiport Adapter PD, 4K In Stock £19.96
CFQX StarTech.com USB C Multiport Adapter In Stock £20.49
CFQX StarTech.com USB C Multiport Adapter, 4K In Stock £31.89
CFQX StarTech.com USB C Multiport Adapter 4K In Stock £31.69
CFQX StarTech.com USB C Mini Dock 4K HDMI In Stock £41.49
CFQX StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £43.64
CFQX StarTech.com USB C Multiport Adapter 2 HDMI In Stock £63.61
CFQX StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £29.52
CFQX StarTech.com USB-C Multiport Adapter In Stock £46.99
CFQX StarTech.com USB C Multiport Adapter In Stock £81.16
CFQX StarTech.com USB-C Multiport Adapter, HDMI In Stock £31.51
CFQX StarTech.com USB-C Multiport Adapter, HDMI In Stock £27.89
CFQX StarTech.com USB-C Triple Monitor Docking Station In Stock £142.84
CFQX StarTech.com USB-C Multiport Adapter - HDMI/DP In Stock £42.02
CFQX StarTech.com USB-C Multiport Adapter - HDMI/VGA In Stock £26.89
CFQX StarTech.com USB-C Speakerphone Dock In Stock £77.32
CFQX StarTech.com USB-C Triple-Monitor Adapter In Stock £85.93
CFQX StarTech.com USB-C/USB-A Multiport Adapter In Stock £51.84
CFQX StarTech.com USB-C Triple-Monitor Adapter In Stock £85.35
Device Type: Laptop
Colour: Black
