StarTech.com USB-C Multifunction Adapter 4K
Quicklinx: C53HWS00 Mfr#: DKT30CHV
Turn your laptop into a compact workstation wherever you work or go, adding video, Gigabit Ethernet, and a USB 3.0 port through USB Type-C (5Gbps). This USB-C multiport adapter for laptops changes the way you work when you're on the move. It lets you create a workstation when you travel, and it's one of the first multiport adapters to integrate a USB Type-C host connection. Now, you can create a permanent or temporary workstation virtually anywhere you go.
It's a versatile and portable way to help you connect additional devices to your port-limited laptop (for example, your Dell Precision, Dell XPS, Samsung Galaxy TabPro S, or Google Chromebook) using its next-generation USB-C port, so it's perfect for mobile work.
This multiport adapter features an integrated and easy-to-use USB Type-C connector. To take full advantage of USB-C and DP alt mode, the adapter converts the video and data capabilities of your laptop's USB-C port into four individual ports. You can save money and use the adapter with your existing peripherals, and with its built-in cable, there's no need to carry around a separate host cable.
The adapter's USB-C connector is small and reversible, which makes connecting it to your laptop faster and easier. Now, you can spend more time working, and less time setting up your workstation. Plus, you can connect the plug with either side facing up, so there's less risk of damaging your laptop port. And because it uses USB-C, the adapter is Thunderbolt 3 data port compatible, so you can connect it to your Thunderbolt 3 equipped laptop.
With a range of convenient features, the travel adapter is ideal for quick setups in conference rooms or boardrooms.
For maximum portability, the combo adapter consolidates multiple ports into a single, lightweight casing. Because the ports are combined into one convenient travel adapter, you can leave your individual single-function adapters at home or at the office.
Plus, the adapter is bus powered, so there's no need to carry around a separate bulky power adapter. With USB-powered performance, you can travel lighter, more efficiently, and with less hassle.
This versatile USB-C multiport adapter for laptops makes it easy to create a mobile workstation when you need it most. It features HDMI (with audio) and VGA ports, so you can easily connect a 4K HDMI or a standard-definition VGA monitor. The adapter gives you an easy way to connect an external display or a projector to your laptop.
Installation is fast and simple, with native support in most operating systems. Plus, the adapter integrates a Gigabit Ethernet port and an additional USB 3.0 port (USB 3.0 is also known as USB 3.1 Gen 1), so you can access a wired network, or connect an additional USB peripheral to your laptop.
Your USB-C equipped host laptop must support video (DP alt mode) to work with this adapter. The adapter does not support USB Power Delivery.
  • Take advantage of the USB-C port on your laptop
    This multiport adapter features an integrated and easy-to-use USB Type-C connector. To take full advantage of USB-C and DP alt mode, the adapter converts the video and data capabilities of your laptop's USB-C port into four individual ports. You can save money and use the adapter with your existing peripherals, and with its built-in cable, there's no need to carry around a separate host cable. The adapter's USB-C connector is small and reversible, which makes connecting it to your laptop faster and easier. Now, you can spend more time working, and less time setting up your workstation. Plus, you can connect the plug with either side facing up, so there's less risk of damaging your laptop port. And because it uses USB-C, the adapter is Thunderbolt 3 data port compatible, so you can connect it to your Thunderbolt 3 equipped laptop. With a range of convenient features, the travel adapter is ideal for quick setups in conference rooms or boardrooms.
  • Bus-powered, for more portability and less aggravation
    For maximum portability, the combo adapter consolidates multiple ports into a single, lightweight casing. Because the ports are combined into one convenient travel adapter, you can leave your individual single-function adapters at home or at the office. Plus, the adapter is bus powered, so there's no need to carry around a separate bulky power adapter. With USB-powered performance, you can travel lighter, more efficiently, and with less hassle.
  • All the ports you need, including 4K Ultra HD
    This versatile USB-C multiport adapter for laptops makes it easy to create a mobile workstation when you need it most. It features HDMI (with audio) and VGA ports, so you can easily connect a 4K HDMI or a standard-definition VGA monitor. The adapter gives you an easy way to connect an external display or a projector to your laptop. Installation is fast and simple, with native support in most operating systems. Plus, the adapter integrates a Gigabit Ethernet port and an additional USB 3.0 port (USB 3.0 is also known as USB 3.1 Gen 1), so you can access a wired network, or connect an additional USB peripheral to your laptop. The DKT30CHV is backed by a StarTech.com 3-year warranty and free lifetime technical support. Notes:
Startech USB-C Multiport Adapter - USB-C Travel Dock with 4K HDMI or 1080p VGA, Gigabit Ethernet, 5Gbps USB-A 3.0 - Discontinued, Limited Stock, & Replaced by DKT31CHVL (DKT30CHV) - adapter - HDMI / VGA / audio / USB - 11.4 cm
Cable
Adapter - HDMI / VGA / audio / USB
Max Output Resolution
3840 x 2160 - 30 Hz
Cable Length
11.4 cm
Connectors
USB-C - male (input)
Connectors (Second End)
HDMI - female (output) , HD-15 (VGA) - female (output) , RJ-45 - female , USB Type A - female
USB / USB 2.0 / USB 3.0 / USB 3.1 Gen 1
4K support, USB power + audio
3-year warranty
P/N: ARMPIVOT, ARMPIVOTE, ARMPIVSTND, ARMSLIM, ARMUNONB, TB33A1C
Cable Type
Adapter 4K support, USB power + audio
Interface Supported
Jacket Material
Plastic
Cable Length
11.4 cm
DisplayPort Alternate Mode support, Auto MDIX
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Google Chrome OS, Apple MacOS X 10.10 - 10.15, Ubuntu 20.04, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
Connectors
24 pin USB-C - male (input)
19 pin HDMI Type A - female (output) , 15 pin HD D-Sub (HD-15) - female (output) , RJ-45 - female , 9 pin USB Type A - female
FCC, RoHS, WEEE, REACH, RCM, UASP (USB Attached SCSI Protocol)
5.4 cm
1.7 cm
72 g
Shipping Width
12.6 cm
Shipping Depth
22.3 cm
Shipping Height
3.4 cm
Shipping Weight
149 g
Limited warranty - 3 years
C53H StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
C53H StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.48
C53H StarTech.com DVI to VGA Cable Adapter - Black - F/M In Stock £7.33
C53H StarTech.com 6 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £8.51
C53H StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
C53H StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.78
C53H StarTech.com USB-C Multifunction Adapter In Stock £47.42
C53H StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £45.81
C53H StarTech.com USB-C to VGA Adapter with PD In Stock £12.06
C53H StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £20.98
C53H StarTech.com USB-C Adapter - PD - Silver In Stock £47.42
C53H StarTech.com USB C Adapter - 4K HDMI, GbE In Stock £26.04
C53H StarTech.com USB-C Multiport Adapter - DVI In Stock £17.11
C53H StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £70.33
C53H StarTech.com Dual USB C Dock - Windows - PD In Stock £87.15
C53H StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0 In Stock £60.64
C53H StarTech.com USB-C Multiport Adapter with Unfolding Cable - HDMI1.4 - USB In Stock £37.45
C53H StarTech.com USB-C Adapter with HDMI & VGA In Stock £27.56
C53H StarTech.com USB-C Multiport Adapter, 4K HDMI or VGA, Type-C Mini Dock In Stock £60.11
C53H StarTech.com USB C Multiport Adapter PD, 4K In Stock £20.67
C53H StarTech.com USB-C Multiport Adapter HDMI In Stock £51.79
C53H StarTech.com USB C Mini Dock 4K HDMI In Stock £42.54
C53H StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £33.64
C53H StarTech.com USB C Multiport Adapter 2 HDMI In Stock £65.89
