StarTech.com USB C Mini Dock 4K HDMI
Quicklinx: GN9TWS00 Mfr#: CDP2HVGUASPD
£41.49 ex VAT
£49.78 inc VAT
This USB-C multiport adapter with HDMI/VGA lets you add vital connections to your MacBook or Windows laptop, through a single USB-C port. The adapter features a presentation mode switch, that when activated ensures the computer will not go into sleep standby or hibernation.
  • Connect a 4K HDMI or 1080p VGA Monitor
    For maximum productivity, connect your USB-C or Thunderbolt 3 laptop to a 4K 30Hz monitor, using this USB-C to 4K HDMI / 1080p VGA multiport adapter. You can also connect to an HDMI projector or TV in a boardroom or other meeting space, to deliver presentations on a shared screen.
  • Presentation Mode Switch
    When you turn on this switch, the USB-C to HDMI adapter prevents your computer from launching its screen saver, going to sleep, or entering power save mode while presenting. Plus, the built-in MicroSD card reader can be used as external storage - ideal for storing & delivering presentations at boardroom/conference room meetings. • Left Switch Position: Enables Presentation Mode • Right Switch Position: Disables Presentation Mode
  • 100W Power Delivery 3.0 Passthrough
    The USB-C adapter lets you power and charge your USB-C laptop during a presentation or while you're working, with a USB-C Power Delivery port. Even if your laptop has only a single USB-C port available, you can keep your laptop powered. Device reserves 15 watts, avoiding video flicker, device dropouts and power overdraw which is commonly seen in other hubs with less reliable power distribution.
  • Add Downstream USB-A & USB-C Ports
    This USB-C multiport adapter offers a USB 3.1 Gen 2 Type-A port (10Gbps), and a USB-C 3.1 Gen 2 port that can be used for power delivery charging, or if power delivery is not required, can be used as a 10Gbps data port for connecting USB-C peripherals.
  • MicroSD 4.0 Card Reader
    This USB-C multiport adapter features a memory card slot, providing fast read and write access for microSD memory cards through USB 3.0. It's ideal for transferring photos, videos or presentations from your SD cards to your USB-C enabled laptop or tablet.
StarTech.com USB C Multiport Adapter, USB-C to 4K HDMI or VGA Display/Video/Monitor with 100W Power Delivery Pass-through, 10Gbps USB Hub, MicroSD, Ethernet, USB 3.1 Gen 2 Type-C Mini Dock - Works w/ Thunderbolt 3 (CDP2HVGUASPD) - docking station - USB-C 3.1 Gen 2 / Thunderbolt 3 - VGA, HDMI - 1GbE
Docking station
Docking Interface
Video Interfaces
VGA, HDMI
12.5 cm x 6.8 cm x 1.6 cm
124.3 g
Grey, black
Gigabit Ethernet
3-year warranty
Docking station
12.5 cm
6.8 cm
1.6 cm
124.3 g
Enclosure Colour
Grey, black
Video
Max Resolution Details
4096 x 2160 - 30 Hz (HDMI only) , 1920 x 1080 - 60 Hz (VGA only)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, USB 3.1 Gen 2
Expansion Slots
1 (total) / 1 (free) x microSD
1 x display / video - VGA - 15 pin HD D-Sub (HD-15) without pin 9 , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C 3.1 Gen 2 with Power Delivery (85 W) - 10 pin USB-C , 1 x USB 3.1 Gen 2 with Battery Charging 1.2 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
Input Device
microSD card reader
1 x USB-C cable - integrated - 13 cm
Wake on LAN, LED indicator, Preboot Execution Environment (PXE) support, Presentation Mode, aluminium/plastic enclosure, 100W power delivery (pass-through)
FCC, RoHS, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 3.0
Apple MacOS X 10.9 - 10.12, Apple macOS 11.0, Apple MacOS X 10.14 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
138.3 g
70 °C
