StarTech.com USB-C KVM Switch, 4K 60Hz
Quicklinx: HFNTWS00 Mfr#: C2-H46-UC2-PD-KVM
Type: KVM switch
Connectivity: KVM
Ports: 2
£150.27 ex VAT
£180.32 inc VAT
This USB Type-C KVM Switch enables users to switch between two USB-C laptops, sharing a 4K 60Hz HDMI monitor, keyboard, and mouse, while simultaneously charging each laptop.
  • 100W Power Delivery Pass-through
    Dual-100W Power Delivery 3.0 pass-through ports (10W reserved) enable the KVM Switch to charge each laptop at up to 90W, using its own dedicated USB-C power adapter. The dual PD passthrough ports allow for charging each laptop, even when they are not connected to the selected port.
  • Universal Compatibility
    The 2-Port KVM Switch works with any operating system, including Windows, macOS, Linux, and ChromeOS. It is compatible with all hardware platforms, such as Intel, AMD, and Apple M1 and M2 devices (e.g., MacBook Pro). Additionally, it works with DP Alt Mode-enabled USB-C, USB4, Thunderbolt 3, and Thunderbolt 4 laptops and devices.
  • Ready for Quick Deployment
    The KVM Switch is bus-powered and includes two 3ft/1m USB-C host cables, allowing for rapid deployment. The small form factor is sturdy and features attached rubber feet, keeping the KVM securely in place during use. The streamlined port layout ensures easy access to the mouse, keyboard, and host connections, while the PD Passthrough and HDMI output are conveniently out of the way - located on the other side of the unit.
StarTech.com 2-Port USB-C KVM Switch, Single-4K 60Hz HDMI Monitor, Dual-100W Power Delivery Pass-through Ports, Bus Powered, USB Type-C/USB4/Thunderbolt 3/4 Compatible - Small Form Factor (C2-H46-UC2-PD-KVM) - KVM switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Performance
Data transfer rate: 480 Mbps
7.1 channel audio support, push button, bus powered
Power Delivery 3.0
AC 120/230 V
14 cm x 7 cm x 1.5 cm
200 g
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Performance
Max Resolution
4096 x 2160 @ 60 Hz
7.1 channel audio support, push button, bus powered, ultrawide resolutions support
Power Delivery 3.0
Status Indicators
Port status, power
1 x HDMI output , 2 x USB 2.0 Type A , 2 x USB 3.0 Type A , 1 x USB-C (power delivery) , 2 x USB 3.2 Gen 2 max 100W pass-through charging
AC 120/230 V
10 Watt
2 x USB-C to USB-C cable - 1 m
MTBF
50,000 hours
FCC Part 15, RoHS, WEEE, REACH, TMDS
14 cm
7 cm
1.5 cm
200 g
Shipping Width
17.2 cm
Shipping Depth
12 cm
Shipping Height
8.5 cm
Shipping Weight
440 g
5 °C
55 °C
20 - 80% RH
Min Storage Temperature
-20 °C
Max Storage Temperature
50 °C
HFNT StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £16.49
HFNT StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £21.31
HFNT StarTech.com 10ft Ultra High Speed HDMI 2.1 In Stock £24.71
HFNT StarTech.com 12ft Ultra High Speed HDMI 2.1 In Stock £33.33
HFNT StarTech.com 2-Port Dual Monitor KVM Switch In Stock £160.75
HFNT StarTech.com 2-Port Hybrid Cable KVM Switch In Stock £39.64
HFNT StarTech.com 2-Port Dual-Monitor KVM Switch In Stock £203.25
HFNT StarTech.com 2-Port Hybrid Cable KVM Switch In Stock £39.51
Type: KVM switch
Connectivity: KVM
Ports: 2
